New to the site with a XJ650 maxim
Discussion in 'Other' started by Bullvine, May 1, 2017.
  1. Bullvine
    Bullvine New Member
    Norfolk Uk
    Hello to all.
    I've had motorbikes all my life from racing to motocross, which I still have. A neighbour of mine was kind enough to give me a very good sample of the xj650 maxim with anti dive forks and twin disc breaks. This bike came from the states in 93, its a 82 version. he had it over 20 years and kept it in a purpose built extension so its in an excellent condition, for the year.
    I have completely stripped down the CD carbs because it sat for so long and the fuel had become varnish. I thought it would have done the trick for smooth running. However time has taken it toll and a complete new kit should be fitted to bring it up to how it should be. I ran it today and it wouldn't idle below 2000 RPM so its either a carb problem of inlet manifold air leak some where.
    What company is best to order complete carb kits with the inlet manifold rubbers? Also is it worth getting them from America.
    Any good advice would be appreciated.
    Regards
    Bullvine
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Click on the link at the top right - XJ4ever.com. He is member Chacal. I don't know if he ships internationally, but he is by far the BEST source for XJ parts. He sometimes is a bit more, but he is fast shipping, and the part is always correct - these bikes have so many versions that very few other than Chacal can know what is correct.
    Start a conversation with Chacal (Len). if the doesn't ship overseas, he may know a reliable source on your side of the pond.
    Have fun!
  3. wifflebat
    wifflebat New Member
    Northern Ireland
    Hey @Bullvine - will you let us know how you get on in terms of delivery. I'd be interested to hear!
    Have you a pic you could share? Mine is an 83 650 Maxim that looks like it's half way through a bobber project. It has twin discs too so would be interested to see if it looks similar
    What are the first three characters of the VIN?
    I ask because the 650 did not come with anti-dive forks.
  5. BikerMomma
    BikerMomma New Member
    Anyone know of anyway to check why a headlight would go out when bike is put into gear?
  6. Toomanybikes
    Tsawwassen bc
    You bike has a relay that turns on the headlight when it starts and the wiring also runs through start button. Sticking switch or the relay may be faulty.
    Do you have a manual for the bike?
  7. BikerMomma
    Would the light assembly be bad? What if I just turned the bike on and didn't even put it in gear it wouldn't even turn on as well.
  8. BikerMomma
    Don't have a manual at all.
  9. Toomanybikes
    Tsawwassen bc
    High beam or low beam ? High beam indicator on dash coming on? Pull the headlight and check for power at plug with test light.
  10. BikerMomma
    No headlight at all is working not high or low. When I start the bike I have no light at all only one that comes on is the light by the license plate.
  11. Toomanybikes
    Tsawwassen bc
    No tail light?
    May be fuse box failure they do get all corroded and fuses look ok but bad connections
  12. BikerMomma
    Just sent you a message
  13. Toomanybikes
    Tsawwassen bc
    This one was not bad but that the first thing to check
