New to this site and to DIY Mechanics
Discussion in 'Hangout Lounge' started by KShockney, Sep 8, 2015.
  1. mark Freeman
    mark Freeman New Member
    Bloomsburg pa
    I'm a newbie to this thread thing and a newbie motorcyclist. Recently purchased a n 81 xj550. Might be interested in the pegs, luggage rack, and do you have the backrest you mentioned in earlier post.
  2. KShockney
    KShockney Member
    Hilliard Ohio
    I do but my girl will be riding with me so I'm going to keep it for her
  3. KShockney
    KShockney Member
    Hilliard Ohio
    Does anyone know the exact measurements of the crush washers needed for brakelines on my bike
  4. Polock
  5. deepearth
    deepearth New Member
    Lakewood, Colorado
    What issues are you having with your brake? Is the piston seizing etc. If your just changing the pads, that's a simple thing.
  6. KShockney
    KShockney Member
    Hilliard Ohio
    Bike is up and running the British still feel a little squishy but I think I might just need new pads they were good but who knows maybe a new disc rotor whatever they're called I didn't actually running strong I know you say after she's been running a while its hard to turn it back on here's my finished product my turn signals aren't working so that needs to be rewired but other than that everything solid
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    It's a good looking bike. Did you test the relay (brown box under tank) for your flashers?
    Gary H.
  8. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Also buy decent bulbs , my experience Chinese bulbs don't draw enough( sometimes) to cause the flashers to flash properly.
    Alan
  9. Polock
    you're not the first person to say that :)
    BaldWonder and jayrodoh like this.
  10. hogfiddles
    Priceless.......ROTFLMAO
    I didn't catch that one. Lol
  11. XJ550H
    looks like led in the rear on the pic
  12. Sarah
    Sarah maxim-um fun
    Indiana
    Hello fellow female XJ rider and wrencher!
    I'm from next door in Indiana :)
    Nice looking bike, I really like the orange! My old man's Vulcan has a rattle can paint job, it looks so good I'd have never guessed it was spray paint.
    Can I see a picture of the windshield you're selling? Thanks
    Have a good one :)
    Here's a picture of my XJ650
  13. XJ550H
    I like the crash/engine protector bars do you know where they came from?
  14. Sarah
    Sarah maxim-um fun
    Indiana
    Thanks! It's a Lindby Linbar. (http://www.lindbycustom.com) Found it at a local custom shop for $100. (they're expensive new!) I think they're mainly for HD's, had to fab the bottom brackets.
  15. hogfiddles
    Welcome home!
  16. KShockney
    KShockney Member
    Hilliard Ohio
    Lol ment brakes....
  17. KShockney
    KShockney Member
    Hilliard Ohio
    That is slick here is windshield it has some scratches I'll try and get better pics
    Sarah likes this.
  18. tombo
    tombo Member
    San Francisco, CA
    Cool looking bike! I like the orange. A lot. Haven't read all of the thread, but looks like another xjbikes success story!
    Do you have pictures of the windscreen mounted on the bike?
  19. KShockney
    KShockney Member
    Hilliard Ohio
    I can't figure out how to mount it to my short bars but if I do I will hit you up
  20. KShockney
    KShockney Member
    Hilliard Ohio
    Over the winter I will be working on perfecting the bike...now I call my bike Riley it sounds bikey. It needs carb work and new front pads and rotors as well as a ton of electrical work all of which I am learning but I need someone local to help teach me
  21. tombo
    tombo Member
    San Francisco, CA
    What carb related issues are you experiencing? I found that the carbs seemed daunting on paper, but were really not too bad to tackle if you follow the right instructions. You have a whole forum of people to help you through the task and you have Len chacal and his massive xj parts supply and knowledge. Some invaluable tools for the job: jis screwdrivers, access to an air compressor and air chuck, wire gauge cleaners and the tiny drill bit Len sells. A manometer and colour tune plug set is also key once you've got your carbs cleaned. Like I said, sounds huge on paper - but I took my rack all the way down and back up in one day, and managed to be thorough enough with help from this forum to earn me a "hole in one". Plan to replace all rubber, fuel needle and seats, and if you want to make it easier to wet set the carbs, get Allen hardware for the bowl drain screws.
    Bottom line is that the carb rack is a detail oriented job, put on your ocd hat and clean clean, clean some more. When I (at long last) put my squeaky clean carb rack back on, it had noticeably more power and ran a lot smoother than I had ever felt. It also solved a fuel rail leak I had, and gave me the tuning range to get my pilot circuits dialed. Now the bike runs to its potential.... And I really owe a lot to the numerous contributors to this forum.
    Rotors: are they worn out of spec? You might be able to get then machined if they are ridged. Measure the width of the rotor with caliper vs. Spec. To check for the grooves, you can hold a straight edge to the rotor to see how deep (if at all) the grooves are.
    Brake pads: I diagnosed my bike as needing New pads falsely at first - the pads on these bikes have the "meat" at an angle, so it will appear that one side is really really worn and the other not as much.. Might be worth sending us a picture if you are unsure.
    Alan63 likes this.
  22. KShockney
    KShockney Member
    Hilliard Ohio
    Hey guys its been a minute thanks Tombo the task seems less daunting now. The pads are worn at a wierd angle which i believe happend when my caliper piston was javked up. The grooves on my rotor are not to bad but id like to replace them anyway. Recently my bike has been sounding different on the top right part of my ingine creating a cleaner whirring vs the gutteral roar or the left side not sure if this is a problem but i plan to look further into it. I believe riding season is over so i need to prep my bike for winter but i thi,k ill do my carbs before winter sets in so i dont have a bunch of fluids that need to go back in my bike laying around.
  23. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Your pads are probably fine. They have an angle to them when new. Maybe 5 degrees or so.
    tombo likes this.
  24. tombo
    tombo Member
    San Francisco, CA
    Exactly
  25. k-moe
    ^ what they said.
    The 650 Maxim caliper is odd in that it pivots instead of sliding. The pads are manufactured at an angle to allow for full contact as the caliper pivots during use.
  26. hogfiddles
    Your pads are fine
  27. rocs82650
    Middle Tennessee
    Are the valves clearance in spec?
    Gary H.
  28. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Maybe your exhaust pipes are loose. I've had that happen.
  29. KShockney
    KShockney Member
    Hilliard Ohio
    I believe my brakes are ok i assumed they were like car brakes just flat. As you all know the whole brake system has been redone and ive bled and bled them i cant figure out why theyre still so squishy. Also my rear brake is starting to squeal real bad im glad its winter now i wont feel pressured to hurry through things. Im going to clean up my bike get it prepped for winter and start fixing up some minor things im still looking for a grab bar if anyone has one.
  30. KShockney
    KShockney Member
    Hilliard Ohio
    Also is there any good carb cleaning walkthroughs that include resetting them
  31. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Church:
    http://xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    And Ammo:
    http://www.xjbikes.com/forums/threa...whole-9-yards-by-rick-massey.2908/#post-23725
    The why and whatfor's:
    http://www.xjbikes.com/forums/threads/the-secret-life-of-carburetors.14751/
    But How does it?:
    http://www.xj4ever.com/inside your carbs.pdf
    Fuel levels:
    http://xjbikes.com/forums/threads/dry-setting-floats.44805/
    http://www.xj4ever.com/setting fuel levels.pdf
    It seems like a lot, but as you mentioned you have all winter and it is actually fun tinkering with them once the gas vapors dissipate! (Fer cripes sakes make sure your in a properly ventilated area). o_O
    Pictures, notes as you step through it.
    You know where to come with questions.
  32. Stumplifter
    near Irma, WI
  33. hogfiddles
    Either You still have some air in there somewhere (most likely), or you have old lines that have gone soft and need to be replaced.
    Rear brakes..... Did you replace the shoes?
    Yes-- you may need to chamfer the leading edges a bit. they may need a little sanding...to remove some glazing
    No-- uh, you better
    Did you clean the drum braking surface?
    You may have dust build-up
  34. KShockney
    KShockney Member
    Hilliard Ohio
    Thanks umm I think I'll dismantle my rear brakes after Christmas i do believe your right. They work fine but probably couldn't hurt to look in there. Carbs will start mid January when cash is back up is getting a set of needles a good idea or a waste?
  35. hogfiddles
    Depends on which needles you're talking about, the condition of them, etc.....
