New XJ 750 guy in North Dallas area
Discussion in 'Hangout Lounge' started by Lusion, Jan 30, 2012.
  1. Lusion
    Lusion New Member
    Dallas, TX
    Figured I'd introduce myself, been lurking the forum since last week. I purchased an '83 XJ 750 last Tuesday that needs some new life. I am finding new small issues everyday and I have to say I'm stumped right as to what I need. Here are some pictures:
    I chopped its butt off and will making a rear fender and seat
    As it sits right now
  2. skillet
    skillet Active Member
    SW TN
    WELCOME from TN! How was it running before you tore it down? What kind of problems are you having? What direction do you want to go with it? What kind of experience do you have with bikes? You need to ask more direct questions rather than "what do I need"...
    skillet
  3. lostboy2
    lostboy2 Member
    Crimora, Va
    Welcome to the site from VA! If you have a question, just ask. There are LOTS of people with lots of experience with just about anything. You will get an answer to any question you might have. Just ask away.
  4. Lusion
    Lusion New Member
    Dallas, TX
    It cranked and started with carb cleaner but the fuel tank was not connected since it needed a good cleaning. I sanded down the tank and found many pin holes in it so that is getting repaired now. Main problems I am having is with the carbs and the front end. The bearings in the triple tree have flat spots, the forks need new seals or rebuilt. I have considered swapping out the triple trees with the ones from an R6 since they will work with different bearings which will give me more fork options. My main issue is the carbs, I am going with a pod filter setup and yes I have read the pros and cons and I'm willing to risk it. The carb issue is the diapghram rings, mine were cracked and broken so I need to replace just that ring but I can not find a replacement for them. Everything I see wants to sell the whole diapghram which I don't need. The main and pilot jet upgrade I can get from chacal I guess.
  5. Lusion
    Lusion New Member
    Dallas, TX
    Thank you
  6. prince_albert3
    prince_albert3 Member
    Rochester, PA
    welcome. Good too have you.
    That fairing looks like the one I recently restored. Came out good. Now i'm just trying to figure mounting. It came with the top bars but no bottom mounts...
    Good luck with your build
  7. Lusion
    Lusion New Member
    Dallas, TX
    Wouldn't be a project if it was easy:
  8. TIMEtoRIDE
    That's only 78 holes :lol: :oops: :lol:
