New XJ....Need Help
Discussion in 'XJ Technical Chat' started by gagewil, Feb 1, 2018.
  1. gagewil
    gagewil New Member
    Tennessee
    Ok, here is my story. I recently acquired a 1981 XJ550 free of charge. I have no experience with motorcycles at all. I understand how an internal combustion engine works, and I have some very basic knowledge from messing with my early 80's Honda 3-wheeler. However, I am very excited about getting this bike up and running. My first question is how can I try to get it started to see if it runs? I have a new battery for it, and I went ahead and put in new plugs and changed the oil. I have not messed with the carbs. The electric is an absolute mess, and it appeared that someone had rigged a couple wires coming from the ignition to the battery. What is the easiest way I can just try to start it ? Is there a way without any electric? I apologize for my ignorance, like I said I have no experience with motorcycles but I figured it is never too late to get started!!!! Also, I have been following the forum for awhile it seems like a good group of folks. Thanks so much!!!!
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    You have much, much reading to do. While I have no idea how to link things I'm sure someone will be along shortly with links to the information overload hour, church of clean, real cost of maintenance, etc.
  3. gagewil
    gagewil New Member
    Tennessee
    Yes, thanks, I figured that. Just looking for a direction to head in.
  4. Tim O
    Tim O Active Member
    Charlottesville, VA
  5. XJ550H
    starter fluid you should at least be able to get it to back fire
  6. XJ550H
    your.voltage goes through the main fuse to the key then back to the fuse box turn on key and see if you have voltage at both sides of the fuses.
    the ignition fuse has a red white wire which runs up to the kill run switch then back to the tci coils and solinoid . it goes through the starter safety relay before it gets to the solinoid
    when you turn on the key do you hear the starter safety relay(under the tank) and the side stand relay under seat click?
    bad side stand switch will prevent the relays from closing also have the clutch safety switch and neutral switch which if not in proper working order will prevent bike from turning over.
    how long has the bike been sitting?
    Maxim or seca xj550.
    most likely your carbs will need to be cleaned to get bike to start
  7. XJ550H
  8. gagewil
    gagewil New Member
    Tennessee
    Thanks, I will mess with it and see what happens
  9. gagewil
    gagewil New Member
    Tennessee
    Its a maxim XJ550, sitting for about 4 years. Thanks!
