no fire
Discussion in 'XJ Technical Chat' started by robtoth69, Aug 21, 2007.
  1. robtoth69
    robtoth69 New Member
    cleveland, ohio
    :x :x My 1983 maxim 750 is giving me Hell!! It sat for 2 years in my garage untouched. I cleaned carbs and got it to fire but it took starting fluid. Once it was warm it ran great. I was even able to ride it. If I turned the bike off it would start right back up fine untill it came to a cold start. I'd go out the next day and get a quick fire when I would put the choke on but after that nothing. changed plugs, oil carbs, and no luck. when I try to start it cold, I also seem to smell gas rich when I get the quick fire on a cold start. PLease Help!!
  2. vinco
    vinco Member
    Hot Springs, Arkansas
    Sounds like the pilot fuel jets are clogged. Clean them better. Did you take the carbs off the bike to clean them?
  3. robtoth69
    cleveland, ohio
    I took off the carbs and when I opened the bowls up I pulled both jets from each carb. the larger jet was fine but I cleaned anyway on all carbs but the smaller jet on all the carbs were packed solid. I used a needle and carb cleaner and I thought I cleaned them well. anything else??
