No muffler, no back pressure?
Discussion in 'XJ Modifications' started by ScarySnowflakes, May 15, 2017.
  1. ScarySnowflakes
    ScarySnowflakes New Member
    New Jersey
    I'm pretty new to this forum as I just got an 82' XJ750 so just bare with me. The question is, if I remove the mufflers will I lose back pressure and need to rejet or something else?
  2. ScarySnowflakes
    New Jersey
    Now I've looked around and there are so many different answers and I thing that's because the question is unclear, so let me make it as clear as possible. Minus new blinkers my bike is stock. I have the stock airbox with stock filter, stock carbs, and stock exhaust. What I have done is removed ONLY the mufflers.
  3. ScarySnowflakes
    New Jersey
    I still have the H-pipe/collector under the bike. What I want to do now is put pipes from the H-pipe down the sides of the bike, in the same position as the mufflers. This is not open headers or straight pipe because the H-pipe is still there. With all that said am I still going to need to rejet? Would adding baffles/silencers inside the two pipes help? Thanks.
  4. XJ550H
    rejetting info is in this thread
    The Information Overload Hour
    carb clean
    IN THE CHURCH OF CLEAN
    the only way you will really know if you need to rejet is to do plug chops.
    (look at the spark plugs).
    +2 main jet sizes for no muffler (open headers) looks like the advice it is giving as a good place to start
