No spark 1982 xj750
Discussion in 'XJ Technical Chat' started by Dflynn926, May 13, 2018.
Tags:
  1. Dflynn926
    Dflynn926 New Member
    Lockport il
    Hello all! I picked up an82 xj750 a few months ago. I am having some issue with spark. I am getting spark on 2 and 3. I get spark on 1and 4 when I first hit the starter and when I let go. I have a new coil, new plugs,new caps. Swapped the magneto and pick-ups. I swapped the tci/cdi. Everything ohmed out correctly. I get power from the cdi when I hit the starter.
    Any help would be awesome!
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    When do you not have spark?
  3. Polock
    check the water in the battery, charge the battery, check the battery voltage while it's cranking, get a new battery
  4. SQLGuy
    SQLGuy Well-Known Member
    So, one new coil? Which one?
    There is no magneto.
    Did any of the behavior change as you've been swapping out parts? Or has it always been intermittent spark on 1/4?
  5. Dflynn926
    Lockport il
    I'm at 11.5 while cranking. It's a new battery.
  6. Dflynn926
    Lockport il
    The clutch side coil, 1/4. Always been intermittent on 1/4. I get spark if I swap the plugs for coils, which is why I replaced the cdi. I had also tested for power on the old cdi and on the orange wire,had no power. I have 6v on current cdi.
    And it was the stator, I replaced.
  7. Dflynn926
    Lockport il
    When I am holding the starter button.
  8. kerriskandiesinc
    NY
    Try the car battery first, that way you can pretty much rune out the battery!!!
  9. Dflynn926
    Lockport il
    I tried a car battery. No such luck
  10. Dflynn926
    Lockport il
    So I believe I tested the pick up coils and I am getting nothing on one of the wires. And .64k on the other.
  11. XJ550H
    for pick up coils you test gray wire to black then test orange wire to black , then test black to ground.
    you do this on TCI connector. not the connector with the red /white wire
    set meter to lowest ohms setting
    Pick-up coils:
    650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    but yes it does sound like a bad pickup
    6 volts is low at tci you will also want to clean connectors and run/kill switch
  12. SQLGuy
    The stator, in the alternator? Nothing to do with ignition, then.
    With the ignition on and the engine not running, you should have battery voltage (definitely more than 6V) at the orange and gray wires at the TCI. This is sinked at the TCI, not sourced there. It's sourced from the Red/White at the coils. If you're seeing only 6V, that's a problem.
    First thing to check would be to disconnect the plug at the TCI and see if it's still dropping to 6V. If it isn't, then that TCI is also bad.
    The Red/White comes from the ignition switch and the fuse box. It's common most of the way, though, so most of its run wouldn't affect just one coil. I think there are separate wires going up to the coils... so if it's a problem in the wire itself or in a bad connector, that's where you would see it.
    Dropping to 6V, though, pretty much means there's a load dragging it down, and there isn't much of anything that can act as a load like that besides the TCI.
  13. Dflynn926
    Lockport il
    I see 6v when I crank the bike. When I am KOEO I get 11v at the TCI
  14. XJ550H
    uncharged/bad battery if you only see 6 volts when cranking you need to get over 10 volts when cranking or bike will not start
  15. SQLGuy
    He's measuring at orange, not at R/W. Orange will be lower, because you're measuring the switched side of the coil primary.
    What are you getting at R/W when cranking?
  16. mr.steffan mussett
    mr.steffan mussett New Member
    norwich,norfolk, england.
    Hi glad it's notf just me with the coils I've got a new coil on the left side 1-4 won't spark yet 2-3 fire OK so tested them but still can't get my head round as to why...
  17. XJ550H
    did you test the pickup coils.
