NOT STARTING...PLEASE ADVISE!
Discussion in 'XJ Technical Chat' started by Palmer650, Nov 20, 2008.
Thread Status:
Not open for further replies.
  1. indy82xj1100
    indy82xj1100 New Member
    Indianapolis, IN
    Update:
    I hooked the fuel lines back up to bottles with vent holes in them... now it's not running on them either.
    I guess my next step will be to drain the bowls and note how much fuel is in each one... and then try to start it and see if they fill back up.
    Is there a possibility that all 4 clogged up at the same time? You would think that it would at least want to stumble. Maybe the fuel "T"s are clogged, even though we had the petcocks on off when we started it at the po's house? I'm positive that I ran carb cleaner through the fuel inlet passages when I cleaned them...
    Any ideas?
    Matt.
  2. indy82xj1100
    Indianapolis, IN
    Update to the update...
    Disclaimer: I don't recomend this, because the gas and fumes going through the shop vac could ignite from a spark or static electricity! I decided to take the risk, but I moved the vac to the middle of the shop and had a fire extinguisher handy...
    I took off the fuel lines and sucked through them with a modified shop vac(lots of electrical tape and a fuel filter). There must have been some crud in the "T" fittings, because she fires right up now and runs good. I still have some fine tuning to do, but that problem is tackled!
    Even though I guess I didn't give enough time for a response to the original post, I hope this may be of value in the future to a fellow XJ'er.
    Matt ;)
  3. sickle44
    sickle44 New Member
    Edmonton, AB
    can anyone tell me exactly how far should the butterflies be opened at rest?
  4. sickle44
    sickle44 New Member
    Edmonton, AB
    One more question, I believe this forum had suggested that the pilot air jet and main air jet placement was as follows: From the jet plate cover hold down screw, the next hole was for the pilot jet (this is the hole in the middle) and the hole on the other side of the carbs is for the main air jet(two holes away from the plate screw hole) However, in my manual if you look at the diagrams the main airjet is directly tied to the tube where the needle jet goes and the pilot airjet is tied to the pilot circuitry. When you blow compressed air through the carb body, the opposite is found true, the middle whole seems to be for the main and the other the pilot? Opening another set of carbs up, I found the airjets placed as the forum suggest, yet it seems to be contrary to what the manual diagram shows.
    A little Help???
  5. sickle44
    sickle44 New Member
    Edmonton, AB
    I find it difficult to believe that no-one has the answers to these questions, I could really use the help?
    Is this a new member thing, or do I somehow smell poorly through the computer, Bad timing, everyone on Holidays???? PLease HEEELLLPPP???
    Hound, sorry in answer to your questions, this is an 82, 750 I'm working with(seca model). By blocking air, I just meant capping the air inlet to the airbox, nothing doin' with the three vac lines on the intakes.
    I had it started or thought I was in going in the right direction, and then, NOTHING again, No friggen fuel getting into the cylinders???
    Petcock = good
    Float valves = good
    Tank = full of new fuel
    Float bowls = full of fuel
    Carbs = can't get any cleaner all passages cleaned a blown out with compressed air.
    Boots = good
    Still wondering if I've got the airjets in incorrectly and exactly how far the butterflies should be open at idle
  6. TheHound
    TheHound Active Member
    Scotia, NY
    Can't speak for anyone else but I've been at the beach for ten days. :Mrgreen:
    The Haynes Manual diagram has the air jets reversed.
    The manual is wrong.
    Go with the forum placement.
    With the throttle closed use a strip of business card to set the butterflies.
    This is where you would start your synch.
    Your carb vacume synch, will actually set the butterflys to the proper openings.
    So there is no exact spec it varies by cylinder, you are synching all cylinders to the weakest one.
  7. sickle44
    sickle44 New Member
    Edmonton, AB
    Thanks Hound,
    There was a time when it was just wanting to go but wouldn't catch and after adjustments, all I get now are enourmously loud back fires. Of course, back firing stems from being too lean? Guess I'll have to try and open up the butterflies a bit more.
    Cheers.
    I tell you, if I knew what kind of flatsides bolted straight in and if they were available, I'd be on them like stink to poo.
  8. JeDaC
    JeDaC New Member
    Philadelphia, PA
    If you are using carb cleaner or starter fluid, it's actually better not to have it on choke, but have the throttle open instead so the starter fluid can be drawn into the carb through the air intake. I've been having a similar problem with my 83 maxim 550. I just got it out of storage after sitting for four years. I cleaned the carbs, but the pilot jets wouldn't come out. The bike would only start if I sprayed starter fluid into the air filter. After changing the plugs, it started and ran if I used starter fluid. I've been using sea foam in the gas. Everyday it gets a little better.
    If your bike is only running after you use the carb cleaner, it may be running on the carb cleaner and not the gas. Did you put new plugs in? It sounds like cylinder #1 is firing, but #4 is not since that's the one with oil and gas on the plug, and the other might be hit and miss.
  9. sickle44
    sickle44 New Member
    Edmonton, AB
    K pulled all the plugs last night,
    #3 was the only one with a build up of carbon,
    So cleaned all the plugs
    Now get this, the plugs I took out were the properly sized actual NGK plugs for the machine, I put the bosch platinums with 'bout 60,000kms on them from my truck back in and the thing fires right up? Funny thing is these NGK plugs are the $15/ plug iridium ones
    I don't get it???!!! Doesn't make any sense whatsoever
    Haven't used any starter fluid whatsoever, don't beleive in it, sorry.
  10. midnightblu
    midnightblu Member
    Austin, TX
    Sickle,
    if only #3 has carbon and you had problems with fouled plugs have you checked your plug caps and possibly re-terminated them? i did the coil chop on mine for similar reasons i couldnt dial in my tune till i got a clean connection to the wire and consistant spark across all 4. my thought about your problem is that you have a weak or rusty connection in either the cap or the coil for #3 since the plug swap went so well.... keeping in mind that your replacement plugs might be gapped better for the weak spark. test your primary and secondary coil windings for both coils and if you see any difference you may be able to confirm this or atleast be certain of what it isnt.
    I bench synched the hitachi's at .002 and the did a warm running adjustment to dial in the idle speed. also by doing that you get very close to right and can use a synch tool to make the last couple adjustments.
    alot of folks use the buisness card method or the little trash bag twist tie wire is another method.
  11. sickle44
    sickle44 New Member
    Edmonton, AB
    thanks will do
    appreciate your thoughts btw.
  12. RickCoMatic
    sickle44 ...
    I wouldn't expect anyone to tell you at the AutoParts Store ... But, Iridium Plugs not only require a Strong Coil Output; but the Iridium Plugs are BEST Suited to Engines which are FUEL Injected with the Lambda Sensor Input.
    Iridium Plugs like to Ignite an Air~Fuel Mixture which has a Computer Controlled system foor insuring that the Mixture reaching the Combustion Chamber is >>> Ideal.
    The Dinosaur "Normally Aspirated" Carbs we have shoot raw gas into the Combustion Chamber nowhere near the level of Atomization to not worry about the FUEL Mixture drowning-out the Arc of an Iridium Plug.
    If you are going to use Iridium Plugs ... You NEED to BE "Dialed-In" and running >> "On the Lean Side" ... with NO Coil Problems or Spark Plugs wires 20 years old, ... otherwise, you risk having a Rich Mixture reaching the Combustion Chamber and Not getting fired by a $15.00 Plug needing a Heavier Wallop than our Stock Coils will provide and a near PERFECT Mixture >> ALL the time ... Not to Misfire.
  13. sickle44
    sickle44 New Member
    Edmonton, AB
    Definitely Good to know,
    Thanks much Rick, and no as you suggested, no one asked me at the parts counter what they were going into?? Then again, what 18year old kid would know that? Or anything for that matter(no offence to any potential 18 year old kids but......)
    It's that good old, it's more 'spensive, therefore, must be better rule. Ahhhh.....
  14. sickle44
    sickle44 New Member
    Edmonton, AB
    Finally have allocated the use of a colour tune, although it cost me a bottle of GlenLivet, Hopefully it'll be worth the $35.
    Course it's not a Dyno and a sniffer but......
    Thanks for everyone's help fellows
  15. yamahamaxim85
    yamahamaxim85 Member
    england
    y do u use prime, as i have a couple of suzukies and they carry on filling the carbs up,if i leave it on prime, wats your compression like,
  16. yamahamaxim85
    england
    me saying that,i cant even start mine up,now. tried every thing, but she wont,,, bugger
  17. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    For the proper operation of these bikes you need:
    A good Battery for cranking and ignition
    Fuel Delivery to each cylinder
    Spark at each cylinder
    Timing, ignition and camshaft and valve
    Compression on each cylinder
    If any of the above are not right the bike will not start or just will not run right.
    The most common proplems
    *Dirty fuel tanks and carbs
    *Bad battery
    *Bad plugs & Ignition wires
    *Valve Adjustment
    Of course there are lots of reasons that can cause a no start condition but if you look at the basics you'll find your problem or at least a clue to
    really whats going on.
    MN
  18. yamahamaxim85
    england
    ta yer i know all that, thanks, its killed me battery,lol,
  19. Palmer650
    Palmer650 Member
    Middletown, MD
    Hey yamahamaxim85,
    What shape are your carbs in? Have you taken them off for a good cleaning yet? I've found that 99% of my non-start issues were solved with a thorough cleaning after the thorough cleaning I thought I did. It's also very important to have a new, strong battery pulling 12.6 V at least with some fresh plugs to give you that "Touch of the starter button fire-up" you're looking for!
    Please tell us more so we can help you get back on the road.
  20. That_Guy
    That_Guy Member
    Pennsauken, NJ
    ............................i agree
Thread Status:
