NOW FOR SOMETHING DIFFERENT
Discussion in 'Other Motorcycles' started by wizard, Jan 7, 2012.
  1. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    How do I take a bow? :D
  2. wizard
    A bit of case polishing while waiting for rings.[​IMG]
  3. darkfibre
    darkfibre Member
    Perth, Australia
    I know everyone has made admiring noises about how good the valve seats look, and I agree they look to be a perfect surface, but its hard to judge scale in the pics. Are they not on the wide side? (I dont know the spec on that donk, but they look a bit wide)
  4. bigfitz52
    Think automotive with that motor. Although you're right, the exhaust might be a tad wide; but I honestly don't think it will matter.
    There is ONE problem though, Wiz--
    It's too shiny. Neither of my SRs were that pretty from the factory.
  5. wizard
    What are you saying, Dark', they are not the right valves ? Personally, I like to see some 'meat' at the edges.
    I hear ya, Fitz, the flywheel casing was in factory black & deeply scored & the sprocket cover comes from a donor bike.
  6. wizard
    We don't want our valves to look like this.[​IMG]
  7. wizard
    Frame finished, rear wheel & both rotors painted[​IMG], tapered bearings fitted to the steering head.
  8. ken007
    ken007 Member
    Brisbane, Australia
    gday wiz, looking good, just for interest sake do you blast/sand your frame yourself and did you paint it?nice and glossy,it looks like it could be powdercoated. i cant tell from the photo,very nice either way, thanks
  9. wizard
    Hi Ken, I hit all the rusty bits with the wire brush, in the electric drill, blast de-greaser into all the awkward areas, rub the whole thing down with 240 wet-dry, fill the chips, rub down again, wash it down with soapy water, rinse, allow to dry (hot air gun in the angles), then spray with a really good quality rattle can, I don't use primer, now, as I find it chips too easily.
  10. ken007
    ken007 Member
    Brisbane, Australia
    thanks wiz, when i eventually finish the rd i will have a crack at doing the frame myself on the next resto.
  11. TIMEtoRIDE
    Very inspiring work - - so much that I had to run out and buy a pair of XT 500"s in "basket case" form !!
    I just don't see how you can sell these bikes when you're done.
    funny oil change tutorial
  12. wizard
    Just space, Time.
  13. wizard
    What we have here is MIKUNI VM34SS.
    I will check that the stock jets are fitted.
    Main.....#300
    Air........#80
    Pilot......#25
    Starter..#50
  14. bigfitz52
    It's a "pumper!"
    I already explained about the white nylon "start" button there, didn't I?
  15. wizard
    Yes apparently it clicks just 1mm to start when the mill is hot. I'm just about to take it apart & find out why,
  16. wizard
    carb write up.link
  17. wizard
    Carb cleaned, glad there was just one of these.[​IMG]
  18. grunt007
    grunt007 Member
    Hey Time to Ride,
    Nice write up link on the carb! Very interesting to say the least. I like the way they broke the whole carb down and explained everything extremely clearly for a slow learner like me. Now if they would just do that with the Hitachi carbs on an XJ Seca 750 like that. Sooner or later I am going to have to tear into mine but it is looking more and more that before I get done with mine I am going to have to go through the entire bike. That's going to take a bit of time for sure so in my case I am going to have to first get caught up on my Honey Dooooo list so that I can have some Peace of Mind when concentrating on my bike. Hope that time comes before 2013? grunt 007, 81'XJ Seca 750 R, Mi.
  19. mtnbikecrazy55
    keep up the great work wiz!!! looking sharp!
  20. wizard
    Some progress.[​IMG]
  21. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    I don't know anything about those bikes but I an curious. What's with the tank built into the top frame tube? I had a '77 Can-am MX bike that had an oil tank there, but it was a two stroke and that was the oil tank for the oil injection system.
  22. bigfitz52
    Engine oil. It's a "dry sump" motor (the off road versions, the TT/XT came first.)
  23. RangerG
    RangerG Member
    Thanks Fitz.
  24. bigfitz52
    I had two SR500s, a '78 and an '80. The '78 was like the one Wiz is restoring, with a disc rear brake; it got smashed to bits in an altercation with a Toyota, along with my collarbone, 2 ribs and my leg. I replaced it with a 1980 model. The '80 had a drum rear brake, I swear the 550 Seca has the same brake. I sold it when kid #2 was born, but hung onto the Norton.
    I sure miss my SR500s. They're more fun than you might believe; impractical as hell but a barrel of monkeys in the right circumstances (tight twisties or wet roads.)
  25. wizard
    Went with the Dunlop TT 100s.[​IMG]
  26. Alive
    Alive Active Member
    Queensland, Australia
    Looking good Wiz
  27. autosdafe
    autosdafe Member
    Lorain OH
    Looks like a lot of fun wish I had a nice project bike
  28. wizard
    I see by the location you've made the leap, Al, how's it going ?
  29. Alive
    Alive Active Member
    Yup, been here 3 weeks but having fun getting a job and selling the last of the NZ stuff... So broke and jobless :)
  30. wizard
    As long as you've got the DBL working..............................
  31. Alive
    Alive Active Member
    DBL? Don't get an handouts until we have been here a couple of years.... I have however now got a job, and a good job so I'm happy now :)
  32. wizard
    DBL = dearly beloved, handouts are for bludgers, glad you're fixed up.
  33. wizard
    Mill back in frame, cylinder honed, new rings fitted & head serviced.
  34. autosdafe
    autosdafe Member
    Lorain OH
    Thing of beauty
  35. wizard
    New HD 530 chain & sprockets.[​IMG]
  36. wizard
    Tank stripped back to bare metal, underside rust proofed.[​IMG][​IMG]
  37. uhoh
    uhoh Member
    BC, Canada
    What did you do to rust proof?
  38. wizard
  39. wizard
    [​IMG]Tank in gloss black.[​IMG]
  40. XJPilot
    XJPilot Member
    Sarnia, ON
    *shakes head*
    I'm sorry, I could have sworn you said gloss black. You must have meant chrome, right? :p
  41. wizard
    Definitely black, pilot.
  42. wizard
    A handy delivery, thanks to my parts coordinator in PA.[​IMG]
  43. wizard
    Tank painting process.[​IMG][​IMG][​IMG][​IMG][​IMG]
  44. mook1al
    mook1al Member
    Talladega, AL
    You gonna trim the tail off that red ziptie?
    Oh...BTW...Nice paint work.
  45. wizard
    mook, that's hooked up to the temporary gas tank, you never mentioned the pencil wedged in the throttle quadrant.
  46. ken007
    ken007 Member
    Brisbane, Australia
    nice job as always wiz, gunna have to teach myself to paint,i already have a good compressor, adds another dimension to the resto doing it yourself.when do you think you will be done?
  47. wizard
    I'm saving up for a bunch of chroming, Ken.
  48. ken007
    ken007 Member
    Brisbane, Australia
    when i started getting prices for chroming it was almost frightening,good luck.
  49. wizard
    I've got a guy ;o)
  50. wizard
    Further progress, brakes & stuff.[​IMG]
