OEM vs. Fram oil filter O-Ring XJ550
Discussion in 'XJ Technical Chat' started by lsc86, Apr 20, 2021.
  1. zemville
    zemville Member
    Philippines
    Is it possible to use the smaller ones considering removing the oil cooler and the union bolt???
  2. LAB3
    LAB3 Member
    Traveling the U.S. with no fixed address
    I've had the same issue pop up on my XS1100. Got a good deal on some NOS filters dirt cheap but the housing o-rings looked awfully thin. Compared them to the one that comes from a Fram and also K&N, they're the same thickness. If you check it against a Wix filter the ring is significantly thicker with those.
    Moral of the story, a light coating of RTV on the ring solves the problem!
