off topic: HHO
Discussion in 'Hangout Lounge' started by stereomind, Jul 14, 2008.
  1. MiCarl
    TheHound has a point (sort of)
    On many motorcycles the armature has fixed magnets, it always supplies peak power. The voltage regulator applies a load to ground to bleed off the excess power. Any additional electricity used is essentially free because it was being wasted.
    Some bikes have an exciter coil instead of fixed magnets. Voltage is regulated by controlling the power to the exciter coil. Any extra electricity usage increases both the power used in the exciter coil and the additional torque to turn the armature.
    On our XJs have an electromagnet armature. The voltage regulator changes the strength of the magnetic field in the armature to control the voltage. Extra power usage requires more electricity to the armature and extra torque to turn the armature.
    I believe automobile alternators are of the 2nd or 3rd type. Any additional electrical load will use up horsepower from the engine.
    I remember an experiment from one of my elementary school science classes. We had a crank operated generator. The thing was real easy to turn until you attached a light bulb, then the energy to run the light had to come from your wrist and it was quite difficult to spin.
    There is no real difference between a generator and an alternator. A generator simply has a mechanical rectifier built in.
  2. Zookie400
    Zookie400 Active Member
    Connecticut
    it always supplies peak VOLTAGE, but not AMPERAGE.
  3. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    seeing as we are already off topic, hence the title of this thread....
    I know nothing of HHO or ANY equivalent, but I do have some questions.
    I hear people say"increase efficency of fuel already burned" this sounds good.
    Is that the principle use of HHO?
    What is the efficiency of my bike?
  4. TIMEtoRIDE
    I have read that the efficiency of a "regular" car is 9%, and I would estimate that an XJ would be 5% , yes, wasting 95 % of the energy in every gallon.
    The most efficient engines are ocean going HUGE 2 stroke diesels, that are able to reach 55% efficiency, running at less than 300 RPM, they have almost no pumping losses, and with 36 inch bores, and 80 inch strokes, every aspect of the engine is designed to save fuel.
    Our bikes are at a performance level of over 100 HP per liter, compared to the new Corvette, it would need to make over 700 HP to reach our state of tune. Think about that the next time your bike starts acting up, you are working on a FINE, high performance piece of machinery.
  5. stereomind
    stereomind Active Member
    Tulsa, OK
    We just got done installing the rig in my Crown Vic. I'll post my findings within a couple of days.. Got a 140mi trip coming up sunday...
  6. TheHound
    TheHound Active Member
    Scotia, NY
    Yes, can't wait to see the results.
  7. wizard
    Hi Stereomind, save me going through all the posts again, have you got a flash arrester in there?
  8. spinalator
    spinalator Member
    Regina, CANADA
    My uncle is an engineer and says diesel engines are around 45-50% efficient and also have more energy/gram compared to gasoline. Gas efficiency is about 30%. He lost me on the explanation but said that higher compression means higher efficiency as well (?)
    The 9% figure seems really low, maybe my KZ750 was that poor, it had leaky carbs.
  9. spinalator
    spinalator Member
    Regina, CANADA
    So if you suck amps off the battery, and you charged the battery off of solar, would that help the efficiency of the whole scenario?
    I think burning diesel to make steam pressure would be efficient as well. Steam can then drive some pistons for a while and the fuel system can shut off for a spell. Plus you can have a steam whistle. They are cool.
  10. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Only thing is when the people on the train want off then you will loose time as well as energy restarting...................
    Jeez I just want to know that someone credible is testing this thing and will give us an accurate rundown of the pros and cons when they are done.
    Sometimes the answer is right under our nose until we find it.
    SOOOO I'll go back to picking
  11. stereomind
    Tulsa, OK
    Wizard - I don't have a flash arrestor yet, although they're available on ebay for about 9 bucks. This car has never backfired, so I'm ok for a couple of days...
    The results from yesterday's trip are not mind-boggling, but I gained about 4-5 mpg on the highway (25mpg total). That's not unheard of with Crown Vics, but this car has almost 200K miles on the clock, 3 bad O2 sensors, and a clogged DPFE circuit.
    Part of the problem is that modern EFI systems will adjust the mixture once they detect a lean condition... A lot of Fords do not have a MAP sensor so they're not easily fooled to go lean, so I'll have to find a way to lean it out by some other means..
  12. TIMEtoRIDE
    Spinalator- - you make me do research !
    OK, maybe not 9% , but it seems 20 % efficiency pops up alot for "regular car" engines , and I retract my 5% estimate for performance bikes- - for now. . .
    http://pesn.com/2006/05/02/9500266_Gun_Engine/
    This guy didn't fully explain exactly how it worked
    I also found a coating 50 times slipperier than Teflon !!!
    Teflon is as slippery as wet ice on wet ice.
    That would make a great piston skirt coating, cam lobes, valve stems.
  13. spinalator
    spinalator Member
    Regina, CANADA
    Steromind, thanks for the update, glad to see you are doing some data gathering.
  14. reelop19
    reelop19 New Member
  15. TheHound
    Scotia, NY
    5 mpg for adding $50 worth of parts, I'll take it.
    My '83 buick gets 14 mpg that would put it at 19 mpg, better then most new trucks.
    That's 110 more miles on a tank full.
    I'm building one as soon as I'm on my feet again.
    Keep the info coming Stereo.
    Thanks.
  16. TIMEtoRIDE
  17. stereomind
    Tulsa, OK
    that thing scoots!
    looks kinda fun... I wonder what he's using for brakes....
  18. TheHound
    Scotia, NY
    165cc that's a 6HP.
    My go kart has a 6 horse it will do 30mph.
    It looks like steering is acomplished by a bar rubbing against the tires.
    I would imagine braking is acomplished the same way.
  19. PaulT
    PaulT Member
    Wilton, NH
    Soooooooooooooooooooooooooooooooooooooo
    anyone else building one yet, or the drop in gas prices recently lure everyone into a false sense of security?
  20. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I got my new cell built, but wiped out my power supply when I hooked up to it. I ordered some new parts from China and I'm told they're in at the post office. Unfortunately, I'll be away until Thursday, so further testing will have to wait ‘til after I'm back. What I did observe, before my power supply went up in smoke, seemed promising. We'll see soon enough.
