oil and petrol blowing out the carb?
Discussion in 'XJ Technical Chat' started by NZXJ750RIDER, Feb 4, 2009.
  1. NZXJ750RIDER
    NZXJ750RIDER Member
    new zealand
    hey guys my spare bike has this problem im thinking a carb problem or possibly engine rings any suggestions i dont really want the cost of a total rebuild and bikes starts runs and idles fine :?:
  2. TheHound
    TheHound Active Member
    Scotia, NY
    The bike runs and idles fine with fuel and oil blowing out of the carbs?
  3. chacal
    "Fine" is a relative term, sort of like the whole beauty/eye of the beholder thing.........
  4. bigfitz52
    Apparently. How about a better description of the problem/symptoms so a diagnosis can be suggested?
  5. Polock
    the only thing that stops gas from coming back out is the intake valve
    where the oil comes from could be several things
    but if the valve closes nothing can come back out
    check the valve clearance first
  6. NZXJ750RIDER
    NZXJ750RIDER Member
    new zealand
    ok just to clarify a little when i say runs starts and idles fine thats exactly wot i meant she just doesnt miss a beat only after a good hard ride does this mysterious liquid appear it leaks out the air box thats why i presume its coming from the carbs it is the colour of oil but is thin and smells of petrol at last check it didnt run on 2 stroke, oil level hardly appears to change i did have it suggested that it might be something to do with a carb butterfly sticking open but no oil should be there so im ruling that out any suggestions
  7. wizard
    My guess is blow by, back pressure forcing fluids up the vent into the air box.
  8. bigfitz52
    "only after a good hard ride" It's probably getting into the airbox through the breather. It's most likely a mixture of oil vapor and probably water vapor. Is it rainy season there? Is your oil overfilled? How MUCH comes out?
  9. NZXJ750RIDER
    NZXJ750RIDER Member
    new zealand
    its the middle of summer here oil maybe a lil over filled though i just thought about that i will check and see if this helps cheers the last time it happened there was about 100mls of fluid
  10. NZXJ750RIDER
    NZXJ750RIDER Member
    new zealand
    hey wizard can u explain blow by a bit further is it a major problem?
  11. wizard
    Worn rings, that's why it's worse when you have been riding hard, have you checked your compression?
  12. NZXJ750RIDER
    NZXJ750RIDER Member
    new zealand
    compression seems a lil low on one cylinder but if anything high on the other 3
  13. bigfitz52
    How many miles on the bike?
  14. NZXJ750RIDER
    NZXJ750RIDER Member
    new zealand
    shes just clicked over 38k kilometres not miles
