oil circulation?
Discussion in 'XJ Technical Chat' started by nablats, Jul 4, 2023.
  1. nablats
    nablats Member
    whitby
    finally started my rebuilt xj650 and ran it for just a minute, all seems fine. I would like to know if there is another way of checking oil circulation as my pipe connection to the oil cooler seems stuck fast, and I dont want to force the issue?
  2. Dan Gardner
    Minneapolis, MN
    You could remove the valve cover and see if oil made it up to the cams
    nablats and k-moe like this.
  3. k-moe
    ^^ this^^
    Checking for flow at the oil cooler won't show you if any oil has gotten to the cams or not.
    nablats likes this.
  4. nablats
    nablats Member
    whitby
    Aye, `tis true. I should be checking valve clearances also, I may have not put shims all back in the original buckets (dropped my egg-box )
  5. k-moe
    When you chake them (and sort them out if needed) make a chart of the shim size that's in each bucket. That way you can have an easier job at the next valve clearance adjustment.
    nablats likes this.
  6. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    When you start the engine on the centre stand, see the oil level drop in the site glass, you think - where did it go? If it does drop (as it should), that means it’s somewhere else....
    Franz and nablats like this.
  7. nablats
    nablats Member
    whitby
    This shall be done. btw - popped off the valve cover and good oil delivery was apparent. Cheers.
  8. nablats
    nablats Member
    whitby
    Its a bit like the Spike Milligan response to the question `what are you doing here?` - -
    `well - everybody got to be somewhere!`
    Franz and a100man like this.
