Oil drain hole ?
Discussion in 'XJ Technical Chat' started by streetmaster, May 30, 2010.
  1. streetmaster
    streetmaster Member
    Since i've got my motor out and on the bench for some simple upgrades, i need to drain the oil out of the motor so i can possibly flip it over to clean the bottom end for paint, but not real sure whare the drain hole is.
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Street what engine are you working on??
  3. streetmaster
    streetmaster Member
    I have an 80 XJ650 that im try'in to degreese so i can throw some paint on it. Right now the motors got a broom stick threw the back mount holes resting on some tires, with a block of wood holding up the front. So now i need to know how to get the oil out. :?: :?: :?:
  4. day7a1
    day7a1 Member
    San Diego, CA
    The drain plug is below the oil filter housing, in the center, front of the engine, it's the lower bolt, 19mm if I remember correctly.
  5. streetmaster
    streetmaster Member
    Ok cool man thanx.
