Oil Filler Funnel - XJ650/700/750/900
Discussion in 'XJ 3D Printing & STL Files' started by Dan Gardner, Apr 18, 2026.
  1. Dan Gardner
    Minneapolis, MN
    I got sick of trying to balance a funnel in the oil fil hole and having it fall out and spill.
    This is a three piece print:
    1. The base piece that is threaded and screws into the oil fill hole.
    2. The tube piece that levels the top and extends the funnel away from the bike a little bit.
    3. The top funnel part.
    It looks a little Dr. Seuss-ish, but it works.
    I'm not sure what the filler cap threads are on the XJ550/XJ1100/XS1100 motors, but if it is the same M27-1.5 thread it would work for those too.
    Three STL files included in attached ZIP file.
  2. RideAlong420
    RideAlong420 Active Member
    USA
    Does the oil degrade the printed plastic? Should these be clear coated before use?
  3. Dan Gardner
    Minneapolis, MN
    A clear coat probably couldn't hurt, but I think it probably depends on what material you use and how you use it.
    I have a small funnel that I've used for a few years printed in PLA and it's fine. I use it a handful of times per year and it's still just fine, even though PLA isn't known for being all that great with solvents. I'm sure if I was using it all day every day it would probably degrade a lot faster.
    Personally, if I was concerned about resistance to solvents, I would print it with PETG. And of course a good coating couldn't hurt if you were worried about it.
    Another hopefully obvious thing to keep in mind is that if you use it in a smoking hot engine you could melt the plastic and that could be a bad time.
