Oil filter
Discussion in 'XJ Technical Chat' started by Scorpion1016, Jan 15, 2017.
  1. Scorpion1016
    Scorpion1016 Member
    Hi everyone been using different oil filters each time I change my oil. I've used wix k&n fram act. Does anybody know which one seems to work the best for their bike. Right now I like fram because it comes with new gaskets.
    The best oil filter is a new one. End of story.
    All the major brands will filter the oil to the necessary degree and then some.
  3. XJ550H
    just make sure you still have the washer and spring for filter positioning
  4. Scorpion1016
    Scorpion1016 Member
    hmm did not know their was a washer and spring. just seems to sit on the bolt that goes through the housing
  5. cgutz
    cgutz Well-Known Member
    SE South Dakota
    You need both the washer and spring. Check xj4ever at top right of screen. Len probably has the parts.
  6. k-moe
    OH it'll sit there all right, but without those parts it won't filter any oil.
  7. Scorpion1016
    Scorpion1016 Member
    Ill check with Len didnt even know those existed. When i do get the parts where exactly do they go?
  8. k-moe
  9. cgutz
    SE South Dakota
    I'm guessing without spring the filter isnt doing much...oil probably blowing past it.
  10. Scorpion1016
    Scorpion1016 Member
    Thanks guys glad I found this out before the season starts
  11. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Using the stock oil filter does the spring go on the concave or convex side of the filter? I looked in the manual and it does'nt say nor the picture shows .
  12. k-moe
    Door dude likes this.
  13. Door dude
    My god k-moe i thank you soo very much the PO had mine all ass backwards. That illustration is wonderful i could see exactly where everything goes
  14. cgutz
    SE South Dakota
    I'm old enough if when removing an oil filter, I don't note the order of washer, spring and which side of the oil filter goes on first, I have to look at the illustration when I install the new oil filter. What does that say about my memory???
  15. hogfiddles
    What does what say?
  16. XJ550H
    not what , that. and who is this that that talks about cgutz?
  17. hogfiddles
    What is cgutz?
    Paul Howells likes this.
  18. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    you all look familiar but I can't place the name . . . .
  19. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    When am I?
  20. cgutz
    SE South Dakota
    Where am I, who am I...
  21. k-moe
