Oil filter
Discussion in 'XJ Technical Chat' started by Scottie1, May 16, 2018.
  1. Scottie1
    Scottie1 Active Member
    Columbia SC
    can someone tell me what way round a xj750 Seca oil filter goes . Does this side go towards the engine or away
  2. chacal
    NOTE: on all paper oil filter elements, the "flat" face of the filter element faces TOWARDS the engine, and the "concave" face of the filter element goes towards the filter housing cover (facing away from the engine case). Sitting within both openings of the oil filter element are the filter grommets. On the "concave" side of the filter, then comes the HCP1493 flat washer, followed by the HCP1494 or HCP1495 compression spring, and finally then the outer cover.
  3. Scottie1
    Columbia SC
    So does the washer not go on last. A picture I saw had the compression spring first then the washer on last and it goes against the filter.
  4. Scottie1
    Columbia SC
    Ah I re read it again and it makes sense now thank you
