One cylinder not firing
Discussion in 'XJ Technical Chat' started by NickMonak, May 23, 2022.
  1. NickMonak
    NickMonak New Member
    Howell, Mi
    Good Morning All,
    I have been working on my 1982 XJ650 Maxim and ran across an issue.
    The bike is an 1982 Maxim with YCIS motor.
    When I pulled it apart it was only running on 3 of the 4 four cylinders.
    I took the carbs apart and cleaned them with the soda blaster and ran them through the ultra sonic cleaner and couple of times. There were bench synced before being put back on the bike.
    My problem is that it still is only firing in 3 of the 4 (#1,#2 and #3 are good) (#4 is the one not firing).
    I have verified that I am getting spark. I open the barb at the bottom of the carb and there is fuel in it.
    What could the issue be? I am a little lost on what to check next.
  2. dkavanagh
    Rochester, NY
    How's compression? When the bike runs, can you tell if #4 pipe gets warm if you hold it above idle? Just wondering if the main jet works?
  3. NickMonak
    Howell, Mi
    I have not checked the compression. The pipe does not get warm at idle, I can try to see if it gets warm with the throttle opened up.
  4. Franz
    This might work to test it. Take the cap off the inlet stub where you attach a vacuum gauge to. If you can get a piece of tube and spray some engine start in there and crank the engine to see if number four runs. If you have pods remove number four and spray the engine start in there. It does look like a carburettor problem or tight valve clearances on four.
    Would this work? Spraying the engine start into the the opening the YICS tool fits into on the right side of the head then replacing the plug and try and start it?
  5. Franz
    Did you clean all of the cold start jets in the float bowls? Perhaps right one is blocked? The jet is in the bowl and this brass tube takes fuel from the bowl into the inlet for cold starting.
    When l first got my bike l didn't know about the above jets. I did the valve clearances still it would not start on all four. I cleaned the carburettors and still had the issue. Then someone on here told me about the float bowl jets. Cleaned them and it started and ran great.
  6. NickMonak
    Howell, Mi
    I did make sure to blow out those tubes when cleaning the carbs. I can try putting the putting starter fluid in the vacuum gauge hole. Thanks for all the advice.
  7. Franz
    Yes just a small amount of starter fluid is all you need to check if it ignites on four. An inlet valve could be the problem also.
  8. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Do you mean you blew out the tube that goes into the bowl well? There is a small, pressed in jet in the bottom of the well that needs to be clear and usually requires a very small wire (guitar string for example) to manually clear. Shooting carb leaner in the well should result in the cleaner shooting out from the bowl bottom hole. Also a strong flashlight aimed into the bowl bottom hole should illuminate the jet hole when observing down the well. There is no shortcut.
  9. Glen F.
    Glen F. Active Member
    Winnipeg Manitoba Canada
    Have you checked to make sure the float level is correct? Might not be getting gas to that one.
  10. to the max
    to the max Member
    Akron, Ohio
    Have you checked all the fuel levels in the bowls?
    oops. Just saw That I’m repeating the question from the previous reply.
  11. NickMonak
    Howell, Mi
    Good Afternoon Everyone,
    Here is an update.
    I have not checked the compression yet.
    I did pull the carbs off and took the #4 one apart. I took the fuel jets out and made sure that they were clear, while they were out I blew air through all the holes and felt the air coming out. I also blew out the tube that is attached to the bowl and made sure it was clear.
    While the carbs were off I put a flashlight in the intake and exhaust side to make sure the vales were opening and closing and they looked good.
    I also did the trick where I took the vacuum cap off and shot starting fluid in there to see if I could hear a difference, I thought it sounded different but I am not 100% sure.
    Also I did rev it up and the pipe got hot once it got higher into the rpms. It sounded better after revving it up as well.
    I think it is getting there, I might need to check a few more things.
  12. Franz
    Are the pilot air jets and passages clean on four?
  13. NickMonak
    Howell, Mi
    I did not check them while I was in there, at least I can take the top off with the carb on. I know there were clean when assembled.
  14. Franz
    Better spraying carb cleaner through them. The air passages could be the problem.
  15. NickMonak
    Howell, Mi
    Next update. The jet in the bottom off the bowl is clogged. I am trying my best to clean it out. Would anyone have a bowl they would be willing to sell if I cant not get it un clogged.
  16. Huntchuks
    East Rochester, NY
    You can do it! Use a piece of guitar string, nice and stiff. You can try acetylene torch files too. Even a sewing needle to pick into the clog. If you use something that bends, like a guitar string, you can also attack it from the bottom of the bowl. To be clean you should be able to shoot a jet of carb cleaner out the other side. A strong flashlight in the bottom of the bowl will show you a nice round hole in the well if cleaned thoroughly, but a smaller jagged hole if not.
    The clog is why the cylinder is not firing right at idle but just at higher RPM's.
    Timbox and k-moe like this.
  17. Dan Gardner
    Minneapolis, MN
    +1 what @Huntchuks said. You can do it. It's a pain, but you can do it.
    But if for some crazy reason you need a replacement bowl, I'm sure somebody around here has one, don't worry about that.
  18. Franz
    Put the bowl in a pot of boiling water for 10 minutes and once dry and cool check with flashlight if it's clear. Use carb cleaner through the jet.
    k-moe and to the max like this.
  19. Timbox
    A bread twist tie is a good size wire to use too. If you don't have any of the above tools at hand. As stated above, you can do it, just your time and if you are not using some good B 12 chem tool I would get some. That stuff really works well for these carbs. Might be a little hard on your hands, but does clean very well.
    Stick with it, you are so close and then she will run the way she should.
  20. NickMonak
    Howell, Mi
    Alright everybody. I believe I have solved the issue.
    I borrowed a compression tester from my dad before tearing the carbs apart and made sure there was compression and we were good (120 psi)
    Took the carbs off again again, found the right size guitar string (it was a #40 jet so I found some that was .37mm in dia. and it fit well)
    Ran it though the jet till clear. Cleaned out the tube as well since I was in there.
    I think it is firing on all 4 now. I just need to get them synced and find/build the rest of the exhaust.
    short_circutz, Huntchuks and Franz like this.
  21. NickMonak
    Howell, Mi
    I do have one more question.
    I called someone to have my carbs synced and he said he could do it but asked me to get some other ducks in a row before bringing it in.
    One of the things he told me to check was the valve clearances.
    I went and read Bigfitz thread on how to do this but I am in need of some clarification.
    When measuring the clearance it says to have the lobe of the cam 90 degrees from the shim/bucket, in the picture that is shown it looks like the it is 180 from the shim/bucket.
    I did measure it from 3 places and got 3 different number each time.
    1st was 180 from the bucket.
    2nd was 90 after the valve closes.
    3rd was 90 before the valve opens.
    I would think that the number should be consistent no matter where the lobe is pointed as long as it is not touching the shim/bucket.
    If someone could let me know I would appreciate it.
    I also do not have the numbers on me but can post them when I get home.
    Thanks for all the help!
  22. dkavanagh
    Rochester, NY
    180 degrees (with the lobe away from the valve bucket) will give you the best reading.
    Franz likes this.
  23. k-moe
    180 degrees. I’ll reread that thread and see if I can find the error and fix it. I don’t recall it being there though. Do you happen to remember if it was in the thread Fitz posted, or in Hogfiddles’ recreation of it?
  24. NickMonak
    Howell, Mi
  25. dkavanagh
    Rochester, NY
    Yes, this is confusing wording... " so that each cam lobe in turn is pointed "skyward" away from its bucket at a 90 degree angle from the surface of the shim"
  26. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    Franz likes this.
  27. NickMonak
    Howell, Mi
    Thanks for the info guys.
    I do have to do some adjusting on all of them.
    I left my results at home again but I think I remember what they were.
    #1. I:.08-.09 E:.21-.22
    #2 I:.14-.15 E:.19-.20
    #3 I:.14-.15 E.20-.21
    #4 I:.08-.09 E:.20-.21
    These should be close. The results are not terrible but I can make them better.
    I got the tool on the way from Motion Pro to hold the bucket down and read what shims are in there and replace them.
  28. NikolaiA89
    NikolaiA89 New Member
    Denmark
    Any update on how it all went? I believe I'm dealing with the same issue on my XJ700. It's not firing on cylinder #3. I have good compression and spark.
  29. Timbox
    If you can spay something into #3 and is if it will fire then? My first time working on these types of carbs took me six cleanings to get them right. All jets and float height right. If #3 has spark and compression is good on all cylinders, you are missing fuel.
