Only runs with choke on,2 cold headers,2 hot
Discussion in 'XJ Technical Chat' started by Jason E Spivey, Jan 28, 2018.
  1. Jason E Spivey
    Jason E Spivey New Member
    Richmond, va
    So I have an 82 maxim 550.Broke the carbs down and cleaned them.The bike only idles and runs with choke on,but has no power.The left 2 headers are cold,and the left is hot.Im stumped on this one.Any ideas?
    so cylinder 1&2 are cold and 3&4 get hot?
    assuming you have cleaned the carbs correctly. did you wet set fuel levels?
    it could be a spark issue
    you need to ohm out the spark plug wires and caps. left side of bike as sitting is #1
    could be bad spark plug caps or the spark plug wire needs to be trimed back due to corrosion
    the spark plug caps unscrew from the wires
    specs
    Pick-up coils:
    650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
  3. Jason E Spivey
    Richmond, va
    Thank you sir,just figured it out.Had 1 and 3 spark plugs crossed
  4. Jason E Spivey
    Richmond, va
    Also I got a cable near the front of my moter,up above the oil filter. I have a small drip of oil coming out of that cable.Do u know what that cable is?
  5. XJ550H
    sounds like the tachometer cable
    the supporting vendor has o rings to fix it or a block off kit if you are not using it
    www.xj4ever.com
    Jason E Spivey likes this.
  6. k-moe
    The how-to aticle for repairing the tachomeer drive:
    Tach Gear Housing Oil Seal replacement w/pics
    The photos are held hostage for the time-being, but the description of the steps is more than adequate to guide you through the repair.
  7. XJ550H
    I see the photo bucket extension no longer works in chrome for viewing the photos
