Oversized Pistons..
Discussion in 'XJ 3D Printing & STL Files' started by a100man, Oct 7, 2022.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    ..how much longer, I wonder, before it's possible to print seriously useful stuff like oversized pistons which are seriously on the unobtainium periodic table
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    If your printer could use the right metallic material the result would still need to be machined, at least on the sides, in the ring grooves, etc.
  3. Kickaha
    New Zealand
    You can get pistons made easily enough, you just need a sample or measurements
  4. a100man
    Bedford, UK
    Yeah, but you're a racer and so money is no object..;)
  5. Kickaha
    New Zealand
    Not for a couple of years now but might be starting back up again sometime next year
  6. chacal
    Question for you FJ600 guys: are the crank main journal bearings on the 600's the same as for the 550 engines? I notice that Yamaha has a supersede on SOME of the 550 bearing listings to the FJ/FZ/YX bearings, but not for all of the different "colors", and I'm thinking that if one "color/size" will interchange, then all of them should............am I missing something? Anyone have any experience with this issue?
  7. a100man
    Bedford, UK
    Hi Len
    Apologies not visited here a while. Unfortunately I have no experience as I never delved further than top end rebuilds - soz.
