peanut tank on an XJ help???
Discussion in 'XJ Modifications' started by xharleyx, Jun 28, 2009.
  1. xharleyx
    xharleyx Member
    Pikeville, KY
    I'm wanting to put a sportster peanut style tank on my XJ. what kind of modifications are needed to do this? sportsters only have one fuel line and my XJ has two fuel lines. will an XJ petcock fit a sportster tank with no modification?
    any help is appreciated
  2. 16ozbud
    16ozbud Member
    louisiana
    I don't know about Harley peanut tanks, but the aftermarket tank I got off Ebay has a threaded hole for the petcock to screw into. I would think Harleys would be the same, but can't say for sure. The Xjs are a bolt on type. The fuel lines shouldn't be a problem. The hardest thing will be mounting the tank. The peanuts have a narrow tunel for a 1.5" backbone. The XJs have this wierd little triple backbone thing. Don't know how intense you're planning on getting with modifying, but the 2 little outside 1" tubes will definitely be in the way.
  3. Zookie400
    Zookie400 Active Member
    Connecticut
    just my opinion......
    i tried a harley peanut tank on my bike.....it looks terrible! the tank is skinny, our bikes are not. it looked terrible. the maxim tank looks beautiful on there now, and bolts up!
  4. Stinky
    Stinky Member
    Flagstaff, Arizona
    I just rec'd a sportster tank I won on ebay. Looks like the mounting won't be too troublesome. I am going out of town for the weekend but I will begin that project when I return. I'll report back when I get it done.
    The XJ petcock won't fit. The bung is on the right hand side also. I plan on relocating to the left side and and just running a single line, gravity-fed petcock.
