Photo of headlight relay wiring?
Discussion in 'XJ Technical Chat' started by Justin F., May 9, 2019.
  1. Justin F.
    Justin F. New Member
    Plainville, CT
    Does anybody know of a location on the site with a photo of the proper wiring setup for an xj650 headlight relay? I have the replacement relay but which wire goes where has become a guessing game.
    If none is already posted, would somebody mind snapping a photo for me? I'd greatly appreciate it!
    head relay 82 xj650.PNG headlight.PNG this is the wiring diagram 2 contact points on relay will read open. the other contacts will read resistance of the coil
    find the 2 with resistance they will be where you put the voltage . white wire and black wire . the red/yellow wire is volts coming from fuse the blue black wire goes to headlight
    relay yellow tab
    you should have 100 ohms between B and W
    on diode test setting you should have .525 between W and L/B
    black probe on w red probe on L/B
    relay marked yellow , numbered 3H5-00
    jayrodoh likes this.
