Piston interchange?
Discussion in 'XJ Technical Chat' started by Colin 85 700, Oct 17, 2019.
  1. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Ok, now knowing ( thanks to you awesome people) the 700 is essentially a 650 bottom. End with 750 jugs, my question is this....
    Do 81-84 750 pistons fit the 85 700?
    They are both 65mm bore stock best as i can tell but every microfiche i can find skips 1984-1979 wtf?
    Both being 2 valve motors, unless the pin height is different should be the same
    Any help is appreciated
  2. Simmy
    According to the parts fiche this piston is unique to the 700.
    Having said that there is always a way :rolleyes:
    When I grafted FZR1000 pistons and block to my 750X motor I assembled it with just #1 piston and the cylinder block.
    I greased the rings before assembly so they completely sealed this cylinder. Then I set the crank so #1 piston was top dead centre.
    With a graduated cylinder I filled the combustion chamber with WD40 to the bottom of the spark plug hole.
    Knowing how much fluid went in I was able to determine the resulting compression ratio.
    In my case I had a small amount to machine off the barrels to bring my compression ratio back close to 11:1 of the 750X.
    In the case of the 700, Yamaha would have had to lower the compression ratio somehow.
    If you put 65 mm pistons in the 650 motor and change nothing else your compression will go way up as you are cramming more volume into the combustion chamber.
    Yamaha could alter the pistons, the rods, the barrels, or the head, probably did all 4.
  3. XJ550H
    The wrist pin height on the 700 pistons is not the same as on the 750 pistons. I can't think of what other differences there are ATM.
