Plane bearings crankshaft XJ 650
Discussion in 'XJ Technical Chat' started by Jeroen, Oct 16, 2022.
  1. Jeroen
    Jeroen New Member
    Belgium
    Hi there! I'm currently working on an XJ 650 4KO 1980. I've dismounted the engine and noticed that the plane bearings on the crankshaft are worn out. I've been having difficulty finding the right set (6 x 4H7-11416-31 "GREEN" and 4x 4H7-11416-21 "BROWN"). I've found some replacement used bearings on Ebay but I'm looking for new ones. Question: Does anyone know if there are any aftermarket replacement bearings available and where can I order them (shipping to Belgium - Europe). Thanks!
  2. Fuller56
    Fuller56 Well-Known Member
    Check with Len at XJ4ever.com or click on his icon on the upper right portion of this screen. He has almost everything for XJ's or can give you info where or if the parts you need are available. One of the best guys to do business with there is. Good luck.
    Jeroen likes this.
