"Pop" all dead.
Discussion in 'XJ Technical Chat' started by tabaka45, Jul 25, 2018.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    All stock '85 XJ700N. Put the key in this morning, hit the start button and got a loud "pop" and all lights, etc are dead. Sounded like a small fire cracker or 22 pistol--sure scared the daylights out of my poor old dog! So I jumped on my faithful Honda Rebel and came to work. I hope this is just a fuse, but I've never heard a fuse pop like that. The bike is stock, stays on a battery tender, and I've never had any electrical issues. Electrical issues are not my strong suit, so any suggestions, no matter how simple, will be appreciated. The battery is fairly new and it has always cranked and started easily--until today.
    Start by checking the fuses. The main on yours is a glass fuse, and those can make noise when they blow.
    The big thing to do if you find a blown fuse is to then find out why it blew.
    Check that the battery terminals are tight, and the terminals to the starter and starter solenoid. Those will make an audible arc if current has to jump a gap, and that can cause the main fuse to blow.
  3. tabaka45
    Brunswick, Georgia
    Thanks. it will probably be next week before I can devote a lot of time to finding the problem. Family reunion this weekend. I'll have to find the starter solenoid.
  4. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    The "pop" could also have been the moment something shorts to ground.
    Of course the fuse would pop shortly thereafter. If it's the main it would explain why nothing else would work. Also if the main fuse pops it narrows things down
    k-moe and Timbox like this.
  5. SQLGuy
    SQLGuy Well-Known Member
    A meter is a must.
    I'd start at the battery, just in case there's some manufacturing defect. Make sure it's got 12V or so.
    Check the connections to the battery. If it was replaced recently, maybe the main 12V or ground connections wasn't installed correctly or tightened completely. Check the other end of the ground cable as well, where it connects to the engine.
    Certainly, the main fuse and other fuses should be checked. If the original fuse box, that itself is a likely cause of problems... you might find scorch marks on the fuse clips.
    Stumplifter likes this.
  6. tabaka45
    Brunswick, Georgia
    Still have not had time to look at the bike, but thanks for the suggestions. I will be back from the family reunion late Sunday. I was trying to remember what could have happened since the last time I rode the bike and I remembered that I installed flexible plastic covers over the plug wires and pushed them all the way up to the coils. Maybe I accidentally pushed some wire against the frame and grounded it. Any way, that’s the first place I am going to look.
  7. tabaka45
    Brunswick, Georgia
    I finally got time to look at the bike today. Took off the seat to check the main fuse and all of the caps were off the battery!! It is a vented Interstate battery so I guess I left them off—hard to believe but I can’t come up with a better answer. The battery was bone dry, so I have filled it with distilled water an it is charging at this time. Two of the caps are missing so I will have to come up with something to use as a plug unless Interstate happens to have an old battery. In In any case, the 30 amp main fuse tests good, so next I am going to check the fuses under the speedometer and tach. Would a dry battery cause a problem other than simply not turning the engine over?
  8. tabaka45
    Brunswick, Georgia
    All the fuses check out good. After about an hour on a trickle charger I got lights but not enough energy to turn over the engine. I’ll give it a day or so and try again. If no go, I will try jumping it and if that works I’ll replace the fairly new battery that I must have killed. The pop is still a puzzle.
    Stumplifter and rocs82650 like this.
  9. Rooster53
    Just a guess here but I suspect the loud pop was the caps being blown off - time for a new battery.
  10. tabaka45
    Brunswick, Georgia
    You could be right if there was gas built up inside the battery and ignited when I hit the starter button. But why would a new battery evaporate all its water in about 3 months? Could a trickle charger do that? Doesn’t seem to be a problem for the other 3 bikes on a trickle charger.
  11. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Global warming?
  12. tabaka45
    Brunswick, Georgia
    Darn those liberals!!
  13. Rooster53
    It doesn't seem like the battery tender should do that unless it wasn't operating properly, and if you are using the same one on all 3 bikes you should be able to rule that out. That said, it would be time to check the charging system on the bike, perhaps it is overcharging slightly contributing to the loss of water.
    I put an AGM battery in my Seca 5 years ago after getting tired of the wet cell batteries and it has performed wonderfully.
    Jetfixer likes this.
  14. tabaka45
    Brunswick, Georgia
    I have a separate charger for each bike. I am beginning a bad charger, just not sure how to check it out.
  15. Jetfixer
    ^^^+1 Rooster53 AMG battery is mucho better. If you boiled your battery time to replace , you may not ever get it to fully charge now.
  16. jayrodoh
    jayrodoh YimYam
    Cleveland
    Funny, my wife's bike went through same thing about a day after you posted. Went to start, pop noise and dead. Turned out battery was bad, I put an AGM battery in. Have those in other bikes and have been extremely happy with them. I agree your old battery is most likely toast now. Sounds like the battery maintainer went south on you, hard to test without a meter but my moms maintainer went south on her Jeep and destroyed the battery as well.
  17. tabaka45
    Brunswick, Georgia
    I'm going to test it tonight, but it was a cheap battery maintainer I picked up at Tractor Supply. Got two of them and this is the first issue I have had. Probably replace them with Battery Tender, Jr's. The Tractor Supply unit is supposed to charge at 3/4 amps, but I've lost any instructions that came with it so I don't know if it is the "floating" type or not. The Battery Tender Jr. is a floating charger and is supposed to cut off when it senses that the batter is fully charged. Probably to prevent what just happened to me.
  18. jayrodoh
    jayrodoh YimYam
    Cleveland
    I have two Battery tender units, one has been on a boat battery for a few years and the other gets moved around bikes. No issues with them. I maintain a couple of bikes for a friend in exchange for winter storage space, total of four Battery Tender maintainers all winter for the last four years and no issues there either. Some other Forum members have reported good results with the Harbor freight ones but I cannot speak to that. Just make sure the maintainer is compatible with the type of battery and you should be good.
  19. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I have a cheap harbor freight battery maintainer. Does the job.
    I bought the deluxe model rather than the cheapest they had. Think I paid like $17-20. Nothing but the best for my bike....
  20. tabaka45
    Brunswick, Georgia
    Well, all’s well that ends well! The battery took a full charge and the bike fired off easily, so I am back in business. The charger is putting out about 13 volts at about .72 amps so it seems to be ok. At about 2500 RPM the alternator is putting out about 13.7 volts. This is an Interstate acid lead battery so I am guessing that staying on the trickle charger all the time hastens the evaporation and I will have to keep a closer eye on the fluid level. Lesson learned.
  21. MattiThundrrr
    My charging method, even with a slow charger designed for off season use, is to connect the pigtails to the battery, but only attach the charger once a month, for approximately 24 hours at a time. It's a little more labor, but I'm paranoid, about both damage to the battery, and leaving an unwatched electrical device running.
  22. tabaka45
    Brunswick, Georgia
    Battery will no longer hold a charge. Bummer. Think I will replace it with an AGM battery. Any suggestions?
  23. k-moe
    I'm currently (ha, ha) using the one on the right.
    jayrodoh likes this.
  24. Jetfixer
    I went to Batteries Plus bought an AMG think I paid around 80 $ but look at it this way a Wally World battery is about 35$ if you only get one season out of it and you replace it over 3 years then this would be a better price . Okay this might be a little extreme most can get a few seasons , care and a tender . I really like the AMG battery no mess from the overflow tube and little risk of boiling the battery. Cheers
  25. Rooster53
    Jetfixer and k-moe like this.
  26. jayrodoh
    jayrodoh YimYam
    Cleveland
    I’ve got a Motobatt AGM in three bikes, two sat though a couple winters without a tender and still fired off in spring. My XJ has been sitting 11 months since accident and still fires up. No complaints here other than initial outlay.
  27. tabaka45
    Brunswick, Georgia
    As it turns out, I found and ordered a Big Crank about an hour ago. $79.95 with free shipping. The reviews were really great, so it is reassuring to know that it is the same as the Magna Power and the Motobatt batteries. Hope I have as good results as you have. Thanks.
  28. Polock
  29. tabaka45
    Brunswick, Georgia
    That’s impressive.
  30. k-moe
  31. turpentyne
    turpentyne Active Member
    Desert SW
    Bah!! You people with your record-holding batteries! where I live, the sun cooks ‘em alive. 2 years max, whatever it is. 3, if you park in garages
  32. Polock
    absolutely
  33. Franz
    I will probably get a Motobatt battery for my bike.
  34. tabaka45
    Brunswick, Georgia
    I saw somewhere that Motobatt made Big Crank batteries. They sure look the same and have the same identification codes I think.
  35. Franz
    Yes Motobatt sell one for the XJ 900f which has 210 cold cranking amps, think the standard one is 190 CCA.
  36. k-moe
    You're a braver man than I.
    MattiThundrrr and chacal like this.
