Problems with 1981 Seca xj750
Discussion in 'XJ Technical Chat' started by RusteeGold, Jun 1, 2015.
  1. Polock
    it might be a good time to take that rotor off and make sure it's on the crank correctly
  3. RusteeGold
    RusteeGold Active Member
    Southern California (RSM)
    OK. I'm an idiot. I didn't believe my last post even as I was writing it. How could the timing be firing 15 degrees AFTER tdc? I decided to test again tonight. There might have been interference from plug wire number 2 on my previous test so I removed plug number two and grounded it far away from plug number 1 this time. The strobe lighted exactly where it should - between the two little lines before tdc. So now I believe the timing is correct. Sorry for the confusion. I feel like a fool....
    It still doesn't run.
  4. RusteeGold
    Does my bike have a ballast resistor?
    I was reading an article on the XJ4ever.com site about ignition. This is what it said: "Using a voltmeter set on 12VDC, connect the positive meter lead to the Orange or Grey coil lead at the TCI. Connect the negative meter lead to the black (negative) lead at the TCI. Turn on the ignition. Voltage should come right up to about 10 - 11VDC. Crank the ignition and observe the meter. Look for a wide voltage swing during cranking. A strong swing indicates that the pickups and TCI are working OK and your trouble is between the TCI and the plugs. Possibly a bad ballast resistor, bad coil, bad plug cap or just corroded connections. Repeat this test for both Orange and Grey coil leads."​
  5. bstig60
    bstig60 Member
    Sharpes, Florida
    OK, makes sense. So you have good compression, fuel with the petcock on PRIME and spark at some time. But not enough to get the engine to start. If you are certain the compression is good and the fuel supply is good, then the only thing left is the spark isn't there sufficiently to start the engine. Either its the ballast resistor or the spark isn't there at the right time. The purpose of the ballast resistor is to increase the intensity of the spark during start-up, then reduce the spark to prolong the life of the ignition coils. Perhaps you should try swapping the ballast resistors between bikes and see if that helps. If it doesn't I would suggest you start tracing out ignition wires. Since the fuse blocks was history, I would suspect some of the wiring connected to it, particularly the wiring for the Ignition fuse and the wires going from the TCI to the coils. Are these wires connected correctly? I would also suspect the wires coming from the PU coils to the TCI as this controls the spark timing. Might think of swapping the PU coils too. But one thing at a time. Wish I was closer, I would come over and give a hand.
  6. chacal
    The article that this information came from dealt with XS1100 models (if I recall correctly).. I don't think that the XJ-series bikes not use such an animal.
  7. wrenchmonkey
    wrenchmonkey Member
    Vancouver Island
    what heat range are the plugs and how are the leads?
  8. RusteeGold
    The plugs are brand new bp7es - stock plugs. The leads are in good shape. I measure 11K ohms from lead end to lead end on both coils and the plug caps measure 5K okms on 1&4 and about 8K ohms on 2&3.
  9. Rooster53
    Did you ever get any voltage readings at the TCI and coils to see if you have a voltage drop occurring in the ignition circuit?
    The symptoms of barely runs, can't give it any throttle without it dying are so typical of a weak spark. If the supply voltage is OK at the TCI, I would do as other members have suggested and swap the coils with the 82. Also, as others have suggested, coils can ohm out OK, but breakdown under the stresses of high voltage. Seems like an easy try compared to swapping carbs and such.
    Any continuity checks done on the pick-up coils? Not just resistance but checked to ground also. It's also another very easy check.
    The other flaky issues related to the tach and instrument cluster have already been explained by the defective signal fuse you found and corrected with the fuse box replacement.
  10. bstig60
    bstig60 Member
    Sharpes, Florida
    I searched thru the wiring diagram and I can't find a ballast resistor. I would question the 8K plug cap resistance on the 2-3 plugs. It shouldn't be any different than 1-4. Have you tried removing the plug cap on those two wires and cutting off a 1/4 inch of the wire, then screw the cap aback on? Another possibility is removing the resistor in the plug caps and going with a resistor plug.
  11. k-moe
    Yamaha specced the inner two at 10K Ohms on some models; the Seca 750 being one of them.
  12. bstig60
    bstig60 Member
    Sharpes, Florida
    Yeah, there is rumor to that affect, but I have not seen it in the factory or the Haynes service manuals that I have. I will be down to my sons where I keep my Seca on Thursday and I will measure the resistance then. Should have done it yesterday when I was there.
  13. Rooster53
    Per Len's catalog:
    NOTE: all XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models originally used 5K resistance value plug caps on all four cylinders. You can use either the OEM or replacement 5K resistive caps and non-resistive plugs, or 0K non-resistive caps along with 5K resistive plugs in order to maintain the original 5K per plug + cap resistance rating.
    My 82 750 Seca came with 5K, although the FSM I have does specify 10K for 2 & 3.
  14. chacal
    Yes, in the original parts books there are listings for "optional" 10K caps "with noise suppression" whatever that means, perhaps used with an factory X1 fairing with built in radio, TV, sofa, and dishwasher (those are big fairings). But I've never seen an original bike or even an original set of used coils with the 10K caps on them (except for XJ550's and XJ700-X models, which do use 10K caps originally).
  15. k-moe
    It is listed in the Haynes and the FSM, and it makes sense that they were fitted to the touring bikes with factory radio, or to the police bikes.
    The extra resistance greatly reduces the RF signal that the coils produce when they fire. Set a portable AM radio next to the bike and you'll hear a pop every time the coils fire. This is the primary reason why cars have resistor plugs.
  16. RusteeGold
    Rooster53 - I have 11.8 volts at the red/white wire on the TCI. I also have 11.8 volts to both coils on either wire when the key is on. I've done resistance checks on the pickup coils - you mentioned some other test - a ground test? How do I do that. (By the way - I think I have mentioned that all 4 spark plugs are firing when I unscrew them and lay them on the engine and hit the starter.)
    Is there a way to measure the intensity of the spark?
    I swapped the coils (along with the attached plug wires) from the non-working 81 to the working 82 - resulting in no change - 82 works with 81's coils and 81 does not work with 82's coils.
  17. k-moe
    Is it orange to blue in color?
    Do you hear it go "snap"?
    Does it hurt when you touch it?
    All are indicators of good spark. A TCI delivers a lower voltage spark over a longer duration than you'd see from a magneto or a modern electronic ignition.
    So.......spark on all four, but no fire.......hmmmm........this is starting to look like a circle I once walked in.
  18. Polock
    could this get condensed into another post with "this is what it does" and "this is what i've done already"
    the answer is getting lost in all the verbage
  19. Rooster53
    That's a decent number, but since there was so much talk about a bad ground you can verify this. When you measure the voltage at the red/white wire (in reference to chassis or battery neg), you are measuring voltage drop across the TCI and any voltage drop that occurs in the ground side of the TCI circuit. So red/white wire = TCI voltage drop + drop across TCI connector contacts, TCI ground wire, splice in main harness, connection to frame, and connection from frame to engine, battery neg cable, and battery terminal to battery.
    If you place the DMM positive lead on the black wire at the TCI, and the DMM negative lead on the battery neg post, then you will be measuring the ground side of the TCI. Theoretically. you would want this to be zero, but under a few hundred millivolts I would think would be normal. When you measure at the R/W wire with a voltage of 11.8 volts, and if you had a defective ground, then you could have a case where the TCI is dropping 9.8 volts, and the resistive ground is dropping 2 volts producing a low voltage issue with the TCI.
    Or, another simpler way would be to place the DMM pos on the R/W wire on the TCI, and the DMM neg lead on the black wire on the TCI. Any excessive voltage drop from either the pos or neg side would show up in this case.
    The caveat to both of those scenarios is you need to be drawing some current so if there is a resistive connection either on the pos or neg side it will be apparent. This normally can be done by checking at power up as at least one coil is usually conducting for approximately 2 seconds, however in your case there is some doubt since you never saw a spark with the 2 second delay. So, check the orange and grey coil wires on the TCI at power up and see if one of them goes low (about 1.5v) for 2 seconds or so. If that is happening, then do the above voltage checks in that first two second period. If neither is going low, then you may need to install a brake light bulb from the R/W wire to the black wire on the main harness TCI mating connector and perform the voltage checks. The brake light bulb will simulate the TCI and you can measure the voltage drop directly across it.
    That's cheating as you have significantly reduced the load on the starter. Have you checked battery voltage during cranking to be sure it stays above 9.5 volts with the plugs installed? The best way to check spark is with all four plugs in and use a spare plug checking one at a time with the other 3 still connected. Or, as was suggested earlier did you ever swap the batteries between the two bikes? I read back through the post where you said the battery was strong, but a defective battery will turn the engine over quite well but not have enough voltage to power the TCI properly.
  20. bstig60
    bstig60 Member
    Sharpes, Florida
    If I recall correctly, if you have low voltage at the TCI, say 9 volts or so, it isn't going to work. Yamaha's TCI system is power hungry for sure. If you have a battery that is borderline, it will shut down. Have you had the battery load tested? If not, take it to an autoparts store or battery shop and they can load test it for you.
  21. RusteeGold
    Polock suggested that I create a post to summarize "what it does" and "what I've done already" - so I'll give it a shot.
    What is does now: The bike has a very hard time starting if it starts at all. The starter cranks and cranks and cranks but the engine doesn't catch and run. Two days ago I was able to get it to run for about 30 seconds by giving is a lot of choke. But it was struggling an did not run well. If I let the choke off or added any throttle it died. Today I have the carburetor off the bike. If I spray a quick shot of starter fluid in each intake port and then crank the starter, it struggles but does not start. Doing the same to my other Seca and it starts up fast and runs at 4000 rpm for a second until the fuel runs out.
    What I 've done: Compression check on all 4 cylinders - 145 to 150 psi per cylinder. Leak-down test - 15 to 18 percent on all four. Cleaned the carbs - twice (carbs works great on my other Seca). Tested coils - 2.7 ohms on primary and 22K ohms on Secondary measuring from cap to cap. I measure almost 29K ohms on one of the coils because they have 10K ohm plug caps.Tested the pickup coils for resistance - seem to be in spec. Tested voltage to the TCI - 11.8 volts. Hooked up a timing light and was able to see that the #1 cylinder is sparking (strobing the light) at the correct location on the reluctor on the crankshaft - within the 2 marks just before TDC. Hooked up the timing light to cylinder #2 and saw that #2 spark is strobing 180 degrees opposite TDC. It seems logical to me that if the timing light is strobing, then there must be current flowing from the pickup coils to the TCI to the ignition coils to the plugs and the timing of the engine must be correct.
    I have a 1982 Seca that I call the Black Widow because it's black and red. My newest Seca is an 81 and I have named it "Chucky" because it's the cause of my nightmares. I've included a picture of the Widow here. I've swapped many parts from one bike to the other trying to identify the problem component. This morning I swapped the batteries and the Widow ran fine with Chucky's battery but there was no change in Chucky.
    Currently the Widow has the following Chucky parts and Chucky has the Widow's parts. The Widow is being driving by my son today and it's running better than it ever has with Chucky's parts. Chucky sits in the garage keeping the 1982 Virago converted to a Cafe Racer company...
    1) Both coils and high tension leads
    2) Battery
    3) Caburetor
    4) TCI, regulator/rectifier and the relay that is connected to the tringular panel where the TCI lives
    The only other thing I can think of that I can swap over would be the pickup coils. But I've already confirmed the timing is correct based on the timing light.
    I have a few more tests I need to do that Rooster53 told me to do. I'll do those tonight.
    This is the Widow (should rename it to Frankenstein based on all the new parts she's got now...)
  22. k-moe
    One thing That I'm not seeing is mention of the valve clearances having been checked. Have they been?
    The Widow looks sweet. You should give us a thread with some more pics of her (or become a premium member and start a showcase)
  23. RusteeGold
    Thanks for the positive comments K-moe. I'm learning a lot but I feel I'm wasting everybody's time 'cuz I'm not finding anything wrong. I did a valve check back on June 9th (buried somewhere in this thread) the intakes were all .005 & .006 and the exhausts were all .007 & .008
  24. Polock
    i am going with valve timing for now. i saw a guy take the cams out of a good running bike to check the shim numbers and when it got together it acted just like this. the exhaust cam was one tooth off.
    i know the #'s are good but gauges can lie.
    if it was a low battery, once it started it should have made enough voltage to run itself, but maybe not (another problem?)
    5K wires, 10K, 0K, it should start, that can be taken care of later.
    did you ever put new plugs in it, their cheap.
    would you say the plugs are wet or dry after you try starting it?
    it really runs like a gazelle and your just messing with us :)
  25. RusteeGold
    Polock
    It's even funnier than that except the joke is on me... not on you guys. I have five bikes - all older model yamahas. Normally when I buy them there is something wrong. For example the Widow cost $250 but it didn't run. Now it runs great. So after fixing four bikes I was ready to treat myself with a good looking bike that ran well and drive it 2400 miles on a summer adventure... now that bike sits... refusing to run. But I'm also an addict... even now I've got my eye on a 1983 Seca 900 about 400 miles from here...
  26. RusteeGold
  27. Quixote
    Quixote Active Member
    Victoria, BC, Canada
    +1 on that.
    I know you have said several times that the cam timing is correct and I don't want to be insulting or anything - but are you really really sure?
    One thing that caught my attention in one of your earlier posts was that "if you get it started, it dies as soon as you apply any throttle". That doesn't sound like an electrical problem, it sounds like either carbeuration or valve timing. And swapping carbs from one bike to the other is pretty solid proof that it isn't the carbs.
    Presumably you've also checked for vacuum leaks in the vacuum line to the petcock, on the carb manifold boots? It would have to be a pretty bad vacuum leak to make a problem like you are experiencing, though.
    And the Black Widow looks awesome.
  28. bstig60
    bstig60 Member
    Sharpes, Florida
    I agree on the cam timing. It just acts like it is timed late. A Seca 900? I almost bought one a few years back, but I have too many bikes already.........
  29. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Agree! I want to see a head-on view to see what you did between the headlight (which looks round, BTW) and the Atari. Also, she looks pretty low! Is that the angle of the pic, or if not, what length shocks on there? Also, did you know there is an Avenger named Black Widow, played by Scarlett Johansen? So yummy, but she's gonna cost more than 250$!
  30. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Nice bike.
    Gary H.
  31. k-moe
    The front end is strapped down for transport. Does make it look nice though.
  32. MattiThundrrr
    Duhhh... I guess the BRIGHT ORANGE RATCHET STRAPS should have been a clue. How'd I miss that?
  33. RusteeGold
    I'm glad everyone likes the Widow. I'll post some pictures of the front and yes it does have a round headlight.
    However I'm glad to report that I found a problem with the 81. Up till now it seems that everything I tested was working so I couldn't figure out what to fix.
    Today I bought a variable spark tester. Basically it's a screw that you twist in or out to adjust the gap the spark has to jump. I hooked it up and the spark can jump at least a quarter of an inch and it looks blue. However I don't get a spark each time. When the starter is cranking it might spark many times then skip once or twice then hit then skip. Keep in mind that I have swapped the ignition coils and the TCI and battery and I have new plugs. The only thing not swapped that has to do with electricity are the pickup coils... Do pickup coils fail slowly? Could that be my problem? How difficult is it to swap the pickup coils with the Widow? It looks like I have to cut wires. Can I even get new pickup coils if that turns out to be the problem?
  34. k-moe
    You do no thave to cut wires. The plug for the pickup coils is the small one at the TCI. You do have to mess with routing the wires though. There is a test for the pickups, but I don't have it handy to look at.
  35. chacal
    XJ750 air-cooled models:
    Pick-up coils:
    650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    I wouldn't cut the wires, although it is a pain to get their harness out from all their routing clips, etc. on their way to the TCI.....
  36. rocs82650
    Middle Tennessee
    I'd check the timing prior to removing the pickup plate (see if the dots on the cams align with the marks on the caps with the mill at TDC). If the cam chain has jumped a tooth or wasn't set correctly that might be the problem.
    Gary H.
  37. RusteeGold
    I double checked the camshafts timing last night. Everything lines up at TDC.
    My pickup coils measure at 657 ohms and 659 ohms.
    But do they sometimes work and sometimes not? Or do they either work or not work?
    Is there a post that explains how to take the pickup coils off the bike?
  38. k-moe
    They either work, or they don't work. There could be an intermittent break somewhere in the wiring harness tough.
  39. rocs82650
    Middle Tennessee
    They're in range but like k-moe said could be a break in the wiring. Got a impact screwdriver? The plate is located with two screws. Try not to disturb the pointer. Get a camera and take pics of how the wiring routes to the TCI. Idk about the 750 but there are two clips assembled with two of the shifter cover bolts the wires route through on my 650.
    Note: The neutral switch and oil level sender feed are also part of this harness.
    Hope this helps.
    Gary H.
  40. Polock
    do you have a link to one of those "variable spark tester" things? It seems like if there's spark sometimes and then it quits, the bike should run sometimes and then just quit.
    no word yet on wet or dry or new plugs yet
  41. k-moe
    A spark gap tester, or high resistance tester. looks like this.
    It is placed inline between the coil and the sparkplug, and the screw is adjusted to increase the air gap between it and the coil to see just how strong the coil is.
  42. rocs82650
    Middle Tennessee
    For members that may not understand completely...the spark will be seen in the window. As the screw is opened the strength of the spark will continue to jump across the window.
    Gary H.
  43. RusteeGold
    That's exactly what my spark tester looks like except I don't have a glass window.
    I decided to buy a used pickup coils from eBay last night. It's already been shipped this morning so I should have it in a few days. Even though I decided to get another pickup coil it doesn' make sense to me that this should fix it but the whole friggin' bike doesn't make sense to me...
  44. Polock
    well that's just dandy but if the plug is fouled and is arching at the base of the insulator that little gadget might lead you astray.
    if you just pull the boot up off the plug a bit you can hear it fire, that's a impressive tool though
    rocs82650 likes this.
  45. RusteeGold
    I have some new information that I don't really understand. I have a video that shows what I did. Here's the link:Timing light:
    I suspected a problem with spark or ignition since everything else seems to be in spec. I hooked up 2 timing lights. The red one in the video is hooked up to plug wire #2. The silver light is hooked up to the #1 wire. In the video you can see the reluctor in the bottom right. The video is in slow motion. In the video the engine is cranking but it did not start.
    From what I understand each wire should either have spark or no spark. However in the video you can see that plug wire #2 sparks every time the reluctor passes its pickup coil. Plug wire #1 fires EVERY OTHER time it passes its pickup coil... What The Heck is going on????
  46. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Nice job of capturing that and slowing it down.
    I don't know what it means but eagerly await an answer.
  47. bstig60
    bstig60 Member
    Sharpes, Florida
    Nice camera work! How did you do that? The Seca 750 uses a waster spark system so from what I understand both cylinders show spark on every revolution of the crankshaft. My first thought would be the #1/4 PU coil. Second would be the connection from the PU coil to the TCI or the wiring from the PU coil to the TCI. Since you have changed the TCI, I doubt its the problem.
  48. RusteeGold
    The camera work was done by my son with his iPhone.
  49. Polock
    Check the pickups from color to color, tci unplugged. black is common so color to color should be pu1 + pu2 and with the tci unplugged the black should be OL to ground.
    don't know the colors, I'm on the phone.
  50. chacal
    The wire colors from the p/u coils to the TCI will match the color of the wires from the TCI to the ignition coils:
    - the ignition coil for the #1/#4 spark plugs is mounted on the left side of the bike, and has the solid orange (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
    - the ignition coil for the #2/#3 spark plugs is mounted on the right side of the bike, and has the solid grey (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
