PROJECT 900
Discussion in 'XJ Technical Chat' started by wizard, Jun 10, 2009.
  1. Hillsy
    Hillsy Member
    Mine was a solution - it just involves a lot of work :lol:
  2. wizard
    Now the dog can see the rabbit.....
  3. Hillsy
    Hillsy Member
    Well, that's one way to get it out....
  4. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    YIKE!
  5. Polock
    couldn't help it
  6. Bushy
    Bushy Active Member
    Jeezazz, too much leverage? Temper? The hammer? Sorry to see that. I only looked away for a second whilst holding your jacket and now look what you've done.
  7. TIMEtoRIDE
  8. wizard
    Time, I have now got 2 options, once I know the S.C. is working properly, I can weld the case back on, or make it a permanent screwed access, soon everyone will want one. 8)
  9. bigfitz52
    Now THAT firmly qualifies as CBE.
    Geez, Wiz, wasn't that a TAD drastic? Did it come out in one big hunk?
  10. wizard
    Yes Fitz, one replaceable piece, I carefully studied the structural integrity of the casing & it's component parts before making the incision.
    I am seriously leaning towards keeping this as a removable access panel.
    I take the view that this is just another modification, much less hazardous than say, stretching the swing arm, or scything metal off same to fit a marginally wider tire.
  11. RickCoMatic
    I think you'll be sufficiently ahead of the game if you retrieve the dropped parts and facilitate the repair through where you made the cut to weld it up and be done with it.
    You are amazing.
    I hope you get it backk together and it Starts right up and don't leak.
  12. Hillsy
    Hillsy Member
    I would suggest a removable / screw on cover as opposed to welding the top back on - you might have some contaminants fall into the case during the welding process that could be terminal for the motor.
    Plus, welding oil contaminated metals is not a very good idea (ask a commercial welder 8O )
    All up - it's a pretty clever mod if it works :wink:
  13. Polock
    if you ever need to do the valves
  14. wizard
    Polock, put my bike back together right now. :evil:
    Found the reason for the slipping starter clutch, cracked outer race.
    FYI. symptoms were: s clutch slipping out when engine cold, once it had been running, no problem, the extra stress of a cold mill just forced the crack in the outer race open not allowing the rollers to grip.
  15. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Had one that cracked like that on a CB1100F I had. Was told it was from a back fire while trying to start it as the timing was off.
    Fortunately, it was located just under the LH side cover :D .
  16. Kiwi
    Kiwi Member
    New Zealand
    All looks awfully familiar... Just as I said earlier Yamaha use this same design on a lot of models from this era and the material is just not up to the task.
  17. bigfitz52
    Looks like it came out of a Virago. (The big V-twin kicked back a lot harder and more often.)
    Apologies, Wiz, I did't realize it was an incision, thought you just took a big hammer to it. Should never have doubted you.
    I would take the piece you cut out, get a few strategic tabs welded onto it and screw-mount it. You could add tabs under one side, and a couple on the outside of the other side, and screw the outside tabs down. Smear Yamabond into the crack and call it a day.
    Much easier to weld tabs to the piece in your hand than try to weld on the motor.
  18. RickCoMatic
    I'll rain on the parade.
    Devils advocate.
    What have you?
    I bet if you don't weld it, ... It will leak.
    The Piece you excised from the bottom of the Case DOES NOT fit the space where it was excised from any longer.
    It's .00245 Inches too small.
    What is it they used to day about Machining a Part after you have measured ... someone else has measured ... and the Foreman measured ... with all three measurements being the same before you make the pass on the stock making the cut, ... because if you must make a Piece that will fit.
    A miss is as good as a Mile.
    The Piece you want to put back into where you took it from is two and a half miles too small.
    It Does NOT fit by the WIDTH of the Cut-off Tool used to make the cut.
    What the width of a Dremel Cut-off Wafer? 20~30/1000ths.???
  19. wizard
    This is how it will be done, I need to form 2 mating surfaces to have any chance of a bolt on 'cap' not leaking, the cut aperture will form one face & that face will be covered with tape, the 'cap' bolted in place with set screws & internal plates, then the gap will be filled with 'Q' bond (which sets immediately and hard enough to drill & tap, if required, but that's not it's role in this instance) the 'cap' can then be unbolted & dressed up, the tape removed & replaced with an RTV gasket. That's the plan..........
  20. TIMEtoRIDE
    I agree Rick, and also the torque stresses of the transmission case ride up to that area.
    Imagine the stresses of pulling a wheelie, and a huge hunk of the tranny case is just goobered in there, (and no offense to Wiz's incredible talents).
    Remember, the oil pan is also open.
    That "Ally solder" is supposed to be stronger than the regular metal, and flows in at 600* to not ruin everything with heat. (270C??)
  21. bigfitz52
    I don't think so. I went back and looked at where he cut it, and it looks like any stressed areas are on either side of the new aperture. As long as it doesn't leak it should be fine.
    I strongly suspect Wiz is not a wheelie kinda guy.
  22. wizard
    Time, pulling a wheelie puts stress on the transmission & final drive, after start up the generator shaft is just spinning..........
  23. TIMEtoRIDE
    I hope so Mr Fitz, but did you take into consideration that it's shaft drive, and the torque of the driveshaft has to go somewhere??
    Maybe we should consult Schooter, the engineer??
    OK, I'm officially and respectfully not liking this. No glue.
  24. TIMEtoRIDE
    Wiz, I would give you a spare engine case, if you were only closer.
  25. wizard
    Thanks for the thought, Time, but don't stress, havn't you seen those working engines at the science museum with great chunks of the casing cut away so little Schooters can see the works?
  26. RickCoMatic
    I think you are abandoning "Pragmatic Engineering" for the sake of a Vanity-inspired endeavor.
    Take a look at the Project with the sensibility of Fail-Safe Engineering.
    You won the Grand Prize. Pick anything off the Top Shelf.
    You deserve to have this Technique named after you like the great life-saving techniques named after Doctors who experimented and now have operations named after them.
    Weld it closed and take a bow!
    Submarines don't need screen doors.
    Your intellectual development of this Repair Technique does not require further development beyond removing that portion of the Case, gaining access to the worn-out or broken parts, facilitating the repair >>> SAVING 30 HOURS OF LABOR <<< and replacing the portion removed by carefully welding the piece back in place.
    It don't git no bedder then nat!
    It don't get no better than that!
    Furthering the process "Because you can" only serves to advance the whole thing beyond the Point of Diminishing Returns.
    Button that job up and take credit for doing it right; because the next guy in line is going to weld it and poke fun at you for wasting a lot of time getting the project finished by making the Piece removable only to have it leak.
  27. schooter
    Off topic a bit, here's a sleeve valve motor from the 40's. The piston slides in a moving sleeve, which slides in YET ANOTHER moving sleeve, which slides in the bore. The 2 sleeves have ports which align to allow the intake and exhaust events. The sleeves slide at half the piston rate. There are no poppet valves or cams.
    The preservation society didn't have the heart to cut up a relic, so they totally replicated this working model on display at Hershey PA. The gold connecting rods move the sleeves.
  28. TIMEtoRIDE
    Thanks Schooter, that was from me.
  29. wizard
    My idea for taming the springs & rollers while they get installed, pour hot wax in there & put in the 'fridge, when all the parts are in place, warm up the hub unit, with an ally' foil shoot under to catch the melted wax.
  30. non_quotidiun
    non_quotidiun Member
    South Western Australia
    I've just read this through, start to finish, (quiet day at work!). Lovely job there Mr Wiz. I am inspired.
    Felt like a blind man at a strip show till Page 26 though!
    PS What do they sing out at Saudi Arabian strip joints ?
    "Show us yer face"
    Love this site and have learnt a whole lot since finding it. Like the definition of "annealed" for instance. As an analogy it's kind of like going to the pub (softening up) after going 28 days without alchohol, (hardening up while at work). Quenching IS necessary.
  31. yamasarus
    yamasarus Member
    Norh Carolina
    I gotta tell ya. I would have taken the long way round and not ever worried about it. I think the Yamaha engineers would agree with me.
  32. wizard
    You wouldn't get any engineer, Yamaha or otherwise, even think of doing what I did, I am a rebel & totaly cavallier & you know what, I don't give a flying @#$%
  33. yamasarus
    yamasarus Member
    Norh Carolina
    I'm happy for you.
  34. wizard
    Mission accomplished, new starter clutch, complete, installed.
    Would I use this method again? you bet your sweet @#$% I wouldn't.........
  35. cds1984
    Hi Wiz,
    How did you glue it back together in the end? Did your wax technique work out for you too?
    Now don't get me wrong... I'm not really thinking about doing it but man does my starter motor slip like a tart! :(
    It is still freaking me out a bit looking at these pictures, i have to tell you.
  36. wizard
    It's not glued, dude, there are 3 plates in back with 6 set screws & RTV gasket. I didn't use the wax in the end, I cut a 1/4" strip of 1mm metal, wraped it around a socket & left a 1/2" tag pointing inwards, this acted as a spring to hold the rollers & gave just enough room for the boss on the gear to engage the rollers, then holding the assembly & my breath, I used long nose pliers & wound the strip around, like an old fashioned sardine tin. Do yours the right way.Wiz....
  37. wizard
    All back together, now, starting & running sweet as, special thanks to Chacal, 'xj4ever', for parts.
  38. bigfitz52
    Now QUICK! Go for a ride before something else goes all pear shaped on you.
  39. wizard
    At the risk of showing hubris, I am confident I have mastered the gremlins & would happily ride from here to, toobucktim.
    That starter clutch fix was a doosy. :eek:)
    BTW what do you think of the tank rack?
  40. Hillsy
    Hillsy Member
    I was going to ask about that - from that angle it looks like a plastic breadboard?
  41. Polock
  42. Hillsy
    Hillsy Member
    Hmmm - a nice HARD bag in front of your crotch. Maybe not such a good idea..... 8O
  43. TIMEtoRIDE
    All that work on the tank and you bolted a rack to it??
    Man, I want another 900 real bad !! This is crazy !
  44. wizard
    Polock, that's the ugliest thing I have ever seen.
  45. wizard
    What sort of bread do you have in your 'burb, Hillsy?
  46. Hillsy
    Hillsy Member
    Not as fancy as yours it seems :wink:
  47. Polock
  48. schooter
    how is that attached to the tank?
  49. wizard
    Bird poop.
  50. schooter
    Ah, I see now, theres some overspray you may want to clean up
