PROJECT 900
Discussion in 'XJ Technical Chat' started by wizard, Jun 10, 2009.
  1. wizard
    Trick of the light, Schoot'.
  2. non_quotidiun
    non_quotidiun Member
    South Western Australia
    I seen a bike just like that one on Ebay, except it was missing the wine rack on the tank !
  3. wizard
    TANK.. The story so far.
    The tank had been sealed by a PO with some form of epoxy, I cleaned it & sealed it with KBS, it failed, KBS gave me another kit, it also failed, I had to get the epoxy (2" thick) out of the bottom corners of the tank, so to enable this, I cut an access hatch in the tank, then removed the sealer & epoxy, soldered the holes & seled again with KBS, the gas fumes found a way through the soldered joint at the 'hatch' that never got sealed, I then made the 'bird cage' tank rack, to cover the joint, the fumes found thier way out again, not much, but enough to p@#$ me off, so I stripped it all back & will clean again & seal the upper part around the 'hatch'. I have taken this oppertunity to fit an aircraft style filler, I cut the old filler spout out with a jig saw & will use S/S self tappers to fix the filler & then seal the whole thing with the KBS.
    I just noticed this thread has had over 51,000 views, that could be some kind of a record??
  4. wizard
    I didn't use self tappers, I tapped the tank & used the hex C/S bolts provided.
  5. SyracuseXJ
    SyracuseXJ Member
    Wilmington, NC
    I think schooter meant that the BIRD oversprayed.... Don't worry schooter... I thought it was funny :eek:)
  6. wizard
    All mended, now......
  7. RickCoMatic
    You do great work, Wizard.
    That's a thing of beauty.
    For Wizard:
    "Great Bikes get built one detail at a time.
    Until you run out of details, ...
    Or, run out of time." --- Richard E Massey 10.04.10 ©
  8. Alive
    Alive Active Member
    Queensland, Australia
    I dig the new fuel cap... Nice work
  9. schooter
    I think the "what did you do to your Yamaha today" thread has more, though a very nice hit count
  10. wizard
  11. cutlass79500
    lawrenceville georgia
    another beautiful bike wizard
  12. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    All I can say is...wow.
