1. Dec 26, 2024: XJBikes.com server migration work has been is completed. Thank you for your patience. SnoSheriff
Pumba the XJ750 project
Discussion in 'XJ Modifications' started by darkfibre, Feb 15, 2010.
  1. darkfibre
    darkfibre Member
    Perth, Australia
    Managed to join the Perth group for the worldwide 'Distinguished gentlemans ride'
    Stunning day out in perfect weather.
  2. darkfibre
    darkfibre Member
    Perth, Australia
    So, Pumbas old engine that is still in running condition has now come in handy:
    Into the spare frame.
    Manifolds on.
    Throttle bodies on.
    Crank trigger on.
    #2&3 coils on.
    Because the rocker cover bolts are designed to tighen fully at a set tension on the rubbers, some care was needed to find a solution. Proper spacers are for later, as is rounded egdes for the brackets.
    #1 coil bracket
    #1 coil in place.
    This is going to be fun!
  3. skylrk62
    skylrk62 Active Member
    Illinois
    Any update on the Efi?
  4. darkfibre
    darkfibre Member
    Perth, Australia
    Yep,
    my modifications to the fuel rail (silver soldering) failed big time. Will be ordering a custom machined aluminium rail in the next few days.
    Budget broken yet again.
  5. darkfibre
    darkfibre Member
    Perth, Australia
    Friday 615kms and Saturday 1,014kms. One thousand miles over the last 2 days!
    Friday evening, Kalbarri hotel.
    Met up with another rider doing the far ride and travelled together for a few hundred ks
    Port Gregory.
    Obligatory gorge pic, Kalbarri seems big on them.
    Cliff risk area! 8O
    1,000ks in one day, I was buggered!
    For once I had packed something useful. This probably saved my ass when it was dusk and heading into the sun.
  6. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Man you're bike is absolutely gorgeous. Looks like you've been having fun! Keep up with the pics love seeing them!
  7. KPXJ750
    KPXJ750 New Member
    New Zealand
    I have just spent the last hour reading through... fantastic job there mate! LOVE IT!
  8. KrS14
    KrS14 Active Member
    St Marys, Ontario
    How's the power of the bigger bore engine? Man I need to get my engine painted like that lol.
  9. skylrk62
    Illinois
    Any updates on your FI project Darkfibre?
  10. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    How awesome is that
  11. mtnbikecrazy55
    Damn, that's some bugs!!
  12. darkfibre
    darkfibre Member
    Perth, Australia
    Celebrating 10,000 miles (16,000klm) since getting Pumba on the road.
  13. skylrk62
    Illinois
    any progress on your efi conversion?
  14. kudoskun
    kudoskun Member
    Minneapolis MN
    I know this post is from awhile ago, but I like the cleanup of the connectors.
    Did you reuse all of the old wiring, then snip and replace the old connectors, or did you fabricate new wiring front to back?
    It looks like you used...off the shelf connectors (radioshack..?) for some of the smaller, non weatherpack adapters. Is that right?
    I have a rat condominium of nesting in my 750 headlight bucket... 8O
  15. darkfibre
    darkfibre Member
    Perth, Australia
    The connectors are just weatherpack and then a standard quick connect for the ignition switch. The mini connectors are standard for the Koso instruments.
    As I had a few harnesses it was easy to find one that had zero corrosion in the wires. The worst harness had green copper conductors near the ends.
  16. kudoskun
    kudoskun Member
    Minneapolis MN
    Long overdue, but how's the bike - still rolling around?
  17. darkfibre
    darkfibre Member
    Perth, Australia
    Bike is now for sale.
  18. skylrk62
    Illinois
    Hey DarkFibre,
    I see you have a XJ750P Alternator. I'm looking to convert mine to the higher output alternator. Is there any XJ750P alternators over there in Australia? I know these are getting to be rare.
  19. darkfibre
    darkfibre Member
    Perth, Australia
    Quite a few XJ750s in perth have police heritage. Non curved wheels are the easiest thinkg to spot.
  20. MiGhost
    MiGhost Well-Known Member
    The 700X/750X waterhead maxim uses the same rotor\stator as the 750P.
    The cover is the same casting, but painted black on the X.
