QUESTION FOR XJ650RJC (Canadian) Seca OWNERS:
Discussion in 'XJ Technical Chat' started by chacal, Aug 7, 2008.
  1. chacal
    Okay, so you've got one of those ultra-rare XJ650RJC Seca models WITH the YICS-headed engine..............
    Now, I've got a question for you. Since you have a YICS head (like the other '82-up XJ650 and all XJ750 engines), does you bike use the '82 XJ650RJ intake manifolds (which are non-YICS heads) or does your engine use the YICS style head intake manifolds?
    You can quickly tell them apart by observing the orientation of the upper and lower mounting holes of each intake #1 to #4, (in other words, left to right as you're sitting on the bike). Image a straight line drawn through the upper and lower intake manifold-to-head mounting bolts:
    non-YICS, the intake manifolds are oriented like this:
    Thanks!
  2. Wannaride
    Wannaride Member
    Sydenham, Ontario
    Mine are like this: \\\\
    why?
    Since you're the identifier king, can you tell me how many of these "rare birds" were made? Mine is #741.
    In other news?
    Got any choke cables?
    tks
  3. chacal
    Hey Wanna, thanks for the input.
    So yours is a red bike? And is it a YICS engined model?
    The non-YICS motors all had the \\\\ orientation, and they use different intake manifolds the YICS-engined bikes (supposedly).
    I'd just like to know for sure what the 650 Seca YICS-equipped engines used, so I can be sure to offer/provide the correct ones to the people who need them!
    As far as how many were made....wow, tough question. Unfortunately Yamaha never released (or, I've never been able to FIND) production figures for any of their bikes of this era.
    Is yours a 15U or a 5V3 model?
    Both of them started with serial number 100101, so in either case, yours is the 640th one made (which is almost the highest serial number that I've seen for either model). If you still have the paper tag with the VIN number on the steering tube, and don't mind sharing the build date of your bike, that would be a good piece of info, also.
    Choke cables: I'm going to assume that the Canadian 650RJ and 650RJC models use the same choke cable as the USA model 650RJ bikes:
    HCP2712 OEM original Choke Cable, for all XJ650 Seca and XJ750 Seca models.
    $ 15.00
    If not, then I'd have to get the original part number to determine what cable would be appropriate for that bike.
  4. Wannaride
    Wannaride Member
    Sydenham, Ontario
    Hiya
    Yep, mine is dk. red (going to stay red, just a flashier version soon)
    It's the 15U. I'll look again for the build date and get back to you, though I think anything paper is long gone!
    Yes, it's a YICS
    Would the choke cable part number be this oem...299088-001 off of bike bandit for xj650rj?
    Another quirky thing. My forks have the air valves (like the 750) would that have been a possible mod to my bike, or did they make the xj650rj with these types of forks???? Please pm me for the shipping and final price to K0H2T0 for the appropriate clutch cable. I might need a solenoid as well...click click click.
    tks
  5. chacal
    Hey Wanna..........well, the problem with the 650RJC is that it's really tough to get info on. Some sources say that they're really Euro model XJ650's, with just a few "minor modifications" but don't always specify what those mods are.
    Looking at the 1980, 1981, and 1982 XJ650 Euro parts diagrams gives no indication of an air-assisted fronk fork on those models, so unless someone else can chime in, that may be one of those dreaded, un-documented "previous-owner installed options".
    The Euro models also do seem to use the standard 650 Seca choke cable:
    HCP2712 OEM original Choke Cable, for all XJ650 Seca and XJ750 Seca models. NOTE: experimental testing has shown that this cable is an excellent reeplacement cable to use on XJ550 Seca models if you substitute "euro" or "clubman" style handlebars for the stock handlebars.
    $ 15.00
    Now, another question for you!:
    a) Is your engine a 650 or a 750 engine? Rumor has it that some of the YICS-version XJ650RJC models actually came with the 750cc engine. You can verify the engine size by looking front and center at the top of the cylinder "jugs" (not the head) and the engine cc size is cast there. And you can verify whether the engine in the bike is original by looking at the flat, machined pad on the crankcase, just behind the clutch cover, and look at the hand-stamped engine code; if it's the original engine in the bike, it should read 15U-000741.
    Thanks!
  6. Wannaride
    Wannaride Member
    Sydenham, Ontario
    Well!
    This just gets more interesting by the moment! The date stamp is 12/81 (that part of the paper is still on. Interesting, in that it was sold to me as a 750, and though none of the paperwork indicates how many ccs (the ownership just says XJC), the look of everything else is clearly 650 RJ (save the air forks). I will look at the engine stamp tomorrow!
    FACINATING!
    Now my parts list keeps getting longer, I'm sure to your liking;-)
    Will forward more.
  7. chacal
    Well, a 15U model code IS for a XJ650RJC, it's just that some people say that some of the "later" (whatever that means) 650RJC models actually came from the factory with a 750 engine....even though Yamaha still called them "XJ650RJC" models.........
  8. Jberg
    Jberg New Member
    Newmarket, Ontario, Canada
    Apparently I also have an RJC model, somewhere along the line I was told it was just an RJ (wish I had known that when I bought the gasket kit - anybody looking for a head gasket for a non-YICS 650?)
    The interesting thing is that I have the YICS head with the YICS intake manifolds i.e. // \\
    My VIN is 15U-000652 stamped on both the engine and frame. and the cylinders indicate 653cc.
    I know the engine was re-built at least once before I got it so there is a chance that it's not the original head... is there any way to tell?
  9. chacal
    Hey Jberg....thannks for the info.
    Actually, the // \\ orientation of the intake manifolds IS correct for all YICS heads that I've ever seen.
    I'm wondering if Wanna's head is an anomoly, or not really a YICS head? Wanna----does the head on your bike actually have the YICS passage (versus just saying "YICS" on the valve cover)?
    As far as telling whether the head is original, there is no way that I know to determine that....they don't have serial numbers on them. After looking at a couple of heads, there appears to be a series of cast numbers on the head, one or some of which may be a production DATE CODE (date the head was pured/cast), and that could be a clue.....obviously, if the head was cast much, much earlier than the bike's build date, or, of course, if the head was cast AFTER the bike's build date, then something would be suspect.
    Perhaps someone else could chime in on that issue, as I just don't know how to decipher those head casting numbers.
  10. TheHound
    TheHound Active Member
    Scotia, NY
    From what I've read here on the forums, I was under the impression that '82 was the first year for air assist on the XJ650RJ american.
    I looked high and low for the nipple on mine and came to the conclusion that early on in its' life the bike had been wrecked and '81 forks had been put on.
    There was a whole thread on it.
    hhmmmm.
  11. chacal
    Sir Mr. Hound: I do not believe that the USA-issue XJ650RJ (5V2 models) used air assisted forks, either. The 1982-up XJ650 MAXIM models used the air forks (the 1980-81 models did not), so it may be those spirits that you are channelling....... :D
  12. TheHound
    Scotia, NY
    Thank you Mr. Chacal.
    I must have misunderstood the post to mean the Seca's not the Maxims.
    Gee, now I know why I couln't find those damn nipples, 1/2 hour I'll never get back.
    :lol: :lol: :lol:
    I haven't channeled any spirits since late saturday night, well early sunday morning.
    :D
  13. chacal
    Mmmmm. The Case of the Missing Nipples. Sounds like something for Sherlock Holmes to solve.
  14. Wannaride
    Wannaride Member
    Sydenham, Ontario
    Hey there...Got enough gunk off to tell that, yah...it's a 748 cc engine. The crank case is stamped 51-2-100839. Just bought the gasket for an xj650rj as well. no workie huh? Will go back out and look at the YICS thang again.
    Now what?
  15. Wannaride
    Wannaride Member
    Sydenham, Ontario
    Ok...dummmdeedumm question: when "reading" the intake manifolds. I must be looking at them incorrectly. Trying to find a picture online of what you mean. It's the head coming from the engine to the carb connected with the rubber boots, no?
    sorry (sooooooo new)
  16. Andreas
    Andreas Member
    Amsterdam (The Netherlands)
    Here i am too, frame 15U-000693, YICS head and / / \ \ intake mainfold.
  17. chacal
    Hey Andreas, thanks for the update. Original engine (should also be stamped 15U-000693 on the frame case pad behind the clutch cover).....also, 650 or 750 engine?
  18. Andreas
    Andreas Member
    Yes, the engine is the original one and the numbers on it matches the frame. According to the carving on the engine and the papers, is a 653 cc.
  19. chacal
    Thanks for the info!
  20. Cptnvortex
    Cptnvortex New Member
    Vancouver
    Bumping a super old thread here, however I thought I would add to the guess on how many were sold in canada. My vin is 15U-000850. So at least 750 sold here.
