Question
Discussion in 'XJ Technical Chat' started by Brandon Griffith, Mar 16, 2021.
  1. Brandon Griffith
    Brandon Griffith New Member
    United States, Ohio
    I have a brand new carb kit for a xj650 the internals of the carbs or whatever. My question is I currently have a xj550 an wanted to clean my carbs an all tht stuff, could I use tht xj650 carb kit on my 550 carburetors?
  2. Simmy
    No. 650 has Hitachi carbs and 550 has Mikuni
  3. Brandon Griffith
    United States, Ohio
    So no way to put the jets an needles an springs ect. tht are brand new into my 550 carburetors. What if a 550 was bored out or exhaust system was customed, air pods stuff like tht wouldn't tht make it like almost mandatory tht youu up the guts inside the carbs?
  4. XJ550H
    mikuni jets are numbered at rate of fuel flow.
    Hatachi carbs are metric drill sizes
    pilot jets are completly different configuration
    drain screws may work
  5. k-moe
    Then you would need parts for a Mikuni carb.
    You may as well be trying to put parts for a Rochester Quadrajet into the 55o carbs.
    It seems to me that you need to do some reading before you get in over your head and end up frustrated.
    Read This First
    Brandon Griffith likes this.
  6. Brandon Griffith
    United States, Ohio
    Thank you! Yeahh deff the thing I'm trying to prevent, getting in over my head.
