r/e xj750 seca brake bleed
Discussion in 'XJ Technical Chat' started by joejr2, Jul 26, 2017.
  1. joejr2
    Santa Fe,NM
    I just noticed that the fluid reservoir diaphram has a small tear in the last fold near the top. Will
    this cause a problem ? Does the diaphram have to be replaced for the master cylinder to function
    properly ?
  2. Jetfixer
    Probably a goos idea to seal master cylinder
  3. Timbox
    That diaphragm is more for moisture control. The cover has two little notches that let the diaphragm more when you apply the brake. The DOT fluid likes moisture, so the diaphragm is there to make sure the fluid is separated from the air that has moisture and the fluid.
  4. Tim morris
    Tim morris Active Member
    Hopatcong NJ 07843
    Go to a local dive shop or Google aquaseal that'll fix any rubber repairs make sure you get the hardener clean it rough it up a little bit and put that on unbelievable stuff I use it on my dive gear all the time and I used it on other mechanical things resistant to oil grease I imagine would be no problem for brake fluid
