Re-chrome parts
Discussion in 'XJ Technical Chat' started by Dan Gardner, Feb 17, 2022.
  1. Dan Gardner
    Minneapolis, MN
    Does anyone have any experience getting parts re-chromed?
    some pieces I’m thinking about:
    Crash bars
    Exhaust
    Decorative pieces on the side of airbox
    Fenders
    Handlebars
    Carb hats
    what kind of results did you get? Was it expensive? Are there things they won’t refinish?
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    i've had loads done, mainly small pieces, but it soon mounts up, think i spent about £200 GBP ,on the cafe racer.
    i doubt they would do the mufflers ,unless they strip down, as theyre too mucky for the chroming tanks
    but the quality of my local re-chroming place is far better than the aftermarket stuff.
  3. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    Sucess depends largely on the quality of the surface. The surface needs to be stripped, sanded and polished until its near-perfect. The chrome platers do all the hard work, but its dirty, labour intensive work and involves carcinogenic chemicals therefore expensive. Crash bars and handlebars are relatively straightforward, I've always had success with them. XJ carb hats normally have rust pitting, and the pitting is difficult to remove. The finished surface is likely to remain pitted without considerable effort and cost. Exhaust headers are ok to chrome however the silencers will need the baffles to be removed. Unless your silencers are in outstanding condition, I'd consider replacing them.
    Are the decorative pieces near the air box steel or plastic? If they are steel there's no problem. If they are alloy, it will need to be pre-plated with copper. I've had alloy chromed, but its expensive and tricky. If the pieces are plastic, you may have a problem. I don't know anyone who can suessfully chrome plastic although it must be possible.
