Rear brake 82 xj750 maxim not braking.
Discussion in 'XJ Technical Chat' started by yamahaxj750maxim, Apr 22, 2021.
  1. yamahaxj750maxim
    yamahaxj750maxim New Member
    friesland
    My rear brake doesn't brake but the thickness of the pads are thick enough i think. When i put the disc in the wheel it just spins around. Help
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I don't see any pads on the shoes at all. Show a different angle.
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
  4. XJ550H
    if you think measure 2mm is thinnest then there is the drum diameter spec
    dd you fasten the disc (brake backng plate to the stay (flat bar wth nut washer and cotter pin)?
  5. XJ550H
    [​IMG] we do not see the lining
  6. Dan Gardner
    Minneapolis, MN
    Is there any friction material at all on those things?
    Also, on my first XJ, the previous owner had put on some super deduper metallic shoes that I didn't like. They didn't seem to want to "bite", it took a lot of pressure on the brake to get a response. I replaced them with some softer organic units from XJ4Ever and they work and feel a lot better. At least for me - I'm sure it's a personal preference.
  7. k-moe
    Even at that angle I can tell that the friction material is gone. OP needs new shoes.
    @yamahaxj750maxim email info@xj4ever to get proper replacements. Instructions included.
  8. JCH
    JCH Active Member
    seattle wash
    Yes shoes are gone, also that axle shaft bolt doesn't look so good and froze into the backing plate is that what I'm seeing in this photo ?
    Another issue I learned is when it comes to adjusting the rear shoe linkage leave it a few turns loose and take the tool or wench with you on the final road test as the shoes realign with the pivot points in the backing plate and tighten up the adjustment setting or locking up the wheel rear if you adjust it to spec on the tight side.
    cgutz likes this.
  9. yamahaxj750maxim
    friesland
    thank you all for your reply's indeed there are no pads at all. Thank you!:)
  10. Huntchuks
    East Rochester, NY
    Check the drum for scoring under the rust.
