Rear brake lockup
Discussion in 'XJ Technical Chat' started by shovel268, Jul 25, 2017.
  1. shovel268
    shovel268 Member
    Edmonton Alberta Canada
    hey guys I put in new brake shoes but took everything apart and cleaned it up put the rear brake pedal back on .the big coil spring behind the foot pedal fell out ,put it back where I thought it belonged .when I turn the adjustment screw the littlest bit the rear wheel is locked up and the peal has is still loose ,what could be the problem ?
    the brake lever on the drum is way far back of where it is supposed to be for starterscloser to the 6:00 position
    remove it and move it a few splines
    notice location of bolt head compared to your location
  3. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    Consider that the "split" on the lever should be generally aligned with the indicator slot on the cover. And BTW, where's your indicator arrow? Here's a pic of my drum (before and after some feverish rubbing, polishing and buffing!) You can see the arrow better when it was rusty in the "before" picture.
    XJ550H likes this.
  4. XJ550H
    with out the indicator arrow aline the split in lever closer to indicator marks on drum
    fiveofakind likes this.
  5. shovel268
    shovel268 Member
    All valuable information thanks guys I'll give your suggestions a try and report back
  6. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Yes....take that lever off and rotate back counter clockwise to where the split is about at the 12:00 position
  7. shovel268
    shovel268 Member
    Good work boys ,got it sorted out .my next issue is I can turn the adjustment screw all the way in ,but the breake pedal dose not build any restance and the wheel just spins ,
  8. Dadoseven
    Dadoseven Active Member
    Omaha
    Check the alignment of your brake pedal on the shaft. There should be a dot on the shaft that aligns with a notch in the brake pedal.
    Then check the brake pedal travel adjustment.
    Stumplifter likes this.
  9. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    The dot... and the notch... what a pair of bastards!
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    X2 what @Dadoseven said. Looking at your second pic, it doesn't look like the front is assembled properly and would just move the brake rod up and down instead of pulling it forward.
    Dadoseven likes this.
  11. shovel268
    shovel268 Member
    Exactly that's my issue what are your recommendations to fix this
  12. shovel268
    shovel268 Member
    IMG_0225.JPG Is this my pedal adjuster, not sure how it works ,Haynes is vague the little spring keeps popping off I'm also not sure about the large coil spring ,on the rear brake shaft ,just seems to flop around.
  13. shovel268
    shovel268 Member
    Your bike is different then mine I have a 81 xj650 maximum I can't seem to line up the dots without interference from the footrest, should I take it off to line up the dots
  14. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Take the brake pedal off, disconnect the rod end from the brake, push the rod forward and turn the splined brake pedal shaft to where you can get the pedal on proper.
    Push gently on the rod... first photo it looks like it may be bent?
  15. XJ550H
    pull pedal off and aline dot and notch
    once you do that you adjust the pedal hight with the adjuster
  16. Dadoseven
    Omaha
    Yes, you are correct. Mine is probably slightly different. Do like @Stumplifter directs; take the brake pedal off of the splined shaft. Rotate the splined shaft so that the brake rod linkage is more up and down ( mine points to about 11:30, nearly straight up and down). The linkage will be close to 90 degrees with the rod. Reattach the brake pedal onto the shaft so that is in the proper position. There should be alignment marks on both pieces.
    In your photo, it appears that the brake rod linkage is more at 9:00; so there is very little front to back travel of the brake rod. Maybe this is why it appears bent?
  17. XJ550H
    please put that in your signiture line or include it in your posts.
  18. shovel268
    shovel268 Member
    You are correct sir it is bent I lowered my jack by mistake and bent it
  19. shovel268
    shovel268 Member
    Thanks I will do that promptly
  20. shovel268
    shovel268 Member
    I'm impressed by your computer skills I'll certainly try your methods
  21. shovel268
    shovel268 Member
    Thank you for your advice I appreciate it very much
  22. shovel268
    shovel268 Member
    Sounds logical
  23. Dadoseven
    Omaha
    We are all here to help you. Let us know when you get your rear brake working properly or if you have more questions.
    Also, as a side note; you can multi-quote, putting more than one quote in a single post; In case you didn't already know that.? Select the +Quote of multiple posts you want and then select the "Insert Quotes" button.... or you can do a different post for each quote. No matter, whichever way you like. ;)
  24. shovel268
    shovel268 Member
    Granny was right you do learn something new everyday thanks for the tip I'm not very tech savvy
  25. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    But you do listen to Slayer... That's a good thing with Matti.
    Some have called me Satan's Son,
    A name I cannot deny.
  26. Stumplifter
    near Irma, WI
    IIRC the pinch bolt for the pedal needs to be removed completely.
  27. shovel268
    shovel268 Member
    1.I marked in blue where my dots are at the moment
    2.I'm wondering about the little spring and which way it goes into the hole
    3. Is this thing facing the right way or is it upside down
    4.what is the purpose of the large spring and is it on correctly
  28. XJ550H
    the little spring is your brake light switch spring . does it have a string or wire on it ? it should be 1 piece.
    blue dotts way out of alingment
    large spring keeps pedal up when riding
    your rod is on correctly
    this link shows parts.
    http://www.partzilla.com/parts/sear...1981/XJ650+-+XJ650H/STAND+FOOTREST/parts.html
    start by disconnecting the brake rod at drum
    then aline the dots. back the pedel adjuster out first
    when alined adjust the pedle up some to hold i up about 1 inch below foot pedel
    make sure the large spring is hooked onto what ever it hooks to you will need some help from a 650 owner on that here
    when your pedel is correct hook up the rod. you may still have to move the rear lever to be able to thread rod through it
    I have to go now but maybe the large spring hooks up same as a 550 I will look when I get home from work and post tomorrow if no one here can help you with the large spring.
  29. Dadoseven
    Omaha
    1. Pretty confident if you line them up, it will fix your problem.
    2. Not positive; I think it is the spring for your brake light switch. Perhaps someone else knows the proper insertion arrangement. I don't see an obvious problem.
    3. Not sure about the way it's supposed to face on your particular bike, but I believe this is the correct orientation. Looks like it is the brake pedal height/ position adjustment. Mine is different. The stop bolt is on the pedal itself and hits against the foot peg. The nut though, should be snug down against where it is threaded through to lock it in place after the position is where you want it after you get the brake pedal aligned on the shaft correctly.
      1. Adjust the screw so that The pedal height should be 1.6 in (40 mm) below the footrest. Screw down the locking nut. Then you have to adjust foot pedal free-play.
      2. Adjust pedal free-play with nut at the rear of the brake link rod to give 0.8-1.2 in (30-40 mm) travel of the brake pedal.
    4. This is the brake pedal return spring, so that after you press on the brake, the pedal goes back to the original position. Check it by pressing down on brake pedal. Does it spring back into starting position?
  30. shovel268
    shovel268 Member
    I appreciate your help
  31. shovel268
    shovel268 Member
    I lined up the marks just to see and the peal is way up in the air which explains the clearance issue with the footrest how am I to adjust the shaft to be able to fit the brake pedal under the foot rest
  32. Dadoseven
    Omaha
    Remove the brake pedal, rotate the shaft clockwise so that when you put the pedal back on with the marks lined up it is in the proper position. From the picture, the marks will then be approximately at the 4 o'clock position.
  33. shovel268
    shovel268 Member
    How do I rotate the shaft I tried with my hands and it didn't budge plus I don't want to grip it with anything do I need to take the whole assembly out to rotate it
  34. Dadoseven
    Omaha
    Does it rotate when you push on the brake pedal at all?
  35. XJ550H
    can you take a photo from the left side of the bike of the assembly
    if you look at the assembly drawing you will see dashed lines rep the frame you can see where the adjuster bolt goes through the frame
    the brake pedal shaft has to be under where the bolt passes through the frame.
    from your photo it looks like it is above the frame
    lock bolt.JPG red arrow
  36. jayrodoh
    jayrodoh YimYam
    Cleveland
    I don't think you have that front crank (or whatever its called) in correctly. Here are some pics showing the correct orientation. What sucks is you have to remove (or maybe swing out of the way) the swingarm to pull this crank out and put it back in the proper way. I had a similar issue when I first put my bike back together.
    These are off my 82 Maxim 650:
    From the side, you can see where the rod hooks through the footrest bracket.
    Here's one from underneath. The bracket must rest against the adjustment screw as shown, this also shows the spring orientation.
    Dadoseven and Stumplifter like this.
  37. jayrodoh
    jayrodoh YimYam
    Cleveland
    Looking at your pic, the adjustment tab is above the screw bracket. You need to pull that crank out and reinstall as shown in my previous post.
    chacal, Dadoseven and XJ550H like this.
  38. XJ550H
    @jayrodoh those are the photos he needs .
    if he backs out the adjuster bolt THEN supports the bike and removes shocks and tire it looks like the swingarm can be pushed up enough to remove brake pedal shaft
  39. shovel268
    shovel268 Member
    No but if I pull on the adjustment rod it moves back and forth
    ya I did that thinking it would give me more room to get in to put the spring in the hole
  40. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Just some more food for thought...when I was overhauling the rear brakes on my 82 xj650 maxim I had to raise/lower the swing arm with shocks removed (can't remember which way I had to go) so I could remove, clean, and lube the brake pedal shaft as it was sticking to the point the spring wouldn't return it. Afterwards everything was extremely smooth and well worth the curse words getting it apart and back together in the proper order.
    Stumplifter and XJ550H like this.
