Rear caliper banjo leak Fj600
Discussion in 'XJ Technical Chat' started by mark1911, Apr 9, 2021.
  1. mark1911
    mark1911 Member
    liverpool uk
    Decided to bleed up my rear caliper and bought some new crush washers. Used the correct torque and tightened it down. However when it comes to bleeding the system it leaks from around the banjo hose area. On taking it off noticed theres a notch cut into the banjo were the leaks coming from, does the notch have to sit a certain way on the caliper to stop the leak.
  2. Timbox
    That is interesting, you a "notch cut into the banjo" not broken off part? If there is a cut than it would make sense that it fits into something. Do you have the old crush washers that should be copper and flat? Does the caliper side have a notch on it? Interesting pic you sent us.
  3. mark1911
    mark1911 Member
    liverpool uk
    Wow how helpful predictive text sorry never read the message B4 posting. Don't comment then if you can't help can't be arsed with sarcasm at the moment.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    I don't have a clue how that will ever work with that notch in there. Did this work previously or are you rehabbing a bike that was not in service? I have never seen a notch in a banjo connection on any bike.
  5. k-moe
    That looks like a gouge from a lock washer.
    Use a flat file to even the surface out. If the gouge is too deep you will need to replace the banjo fitting.
    chacal likes this.
  6. mark1911
    mark1911 Member
    liverpool uk
    Ordered a new hose braided this time, must of been damage from the previous owner never tried bleeding it up till now.
    k-moe and Huntchuks like this.
  7. k-moe
    Check the date codes on the front lines. They might need to be replaced too.
    mark1911 likes this.
  8. mark1911
    mark1911 Member
    liverpool uk
    Yeah thanks but already replaced them with braided lines
    Timbox and k-moe like this.
