Rear Shocks on a 84 SECA 750
Discussion in 'XJ Technical Chat' started by RICKTOR, Aug 20, 2018.
Tags:
  1. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    Hey guys I am having a bit of trouble with my rear shocks. During this bikes long sit I guess the oil leaked out and no I need to service them... Is there a rebuild kit for these or a way to replenish the fluid.
  2. Toomanybikes
    Tsawwassen bc
    They are a sealed shock. My shocks are toast as well, just a spring with no dampening left. Rear end bounces around in bumpy turns. Replace. @chacal has a new set of oem ones big$$. Icon(Koni) makes a similar replacement but quite pricey as well.
  3. Jetfixer
    EMGO is an alternative about 100$ on eBay 325mm from center to center is measurement they give.
  4. Toomanybikes
    Tsawwassen bc
    But are they any good ? Have Progressive ones on my xj650rjc and pretty good in the fast bumpy turns. I want a decent shock with piggyback to match the oem ones
  5. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    Can you provide a link?
  6. Jetfixer
    Go to eBay put in XJ rear shocks just looked at them 129$ was buy it price. Be cautious of the shocks with the reservoir look cool , but have read some have had problems with leaks , these were on eBay from Australlia .
  7. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    cool but I can't think they would last to long for 150$
  8. k-moe
    Cost doesn't often have much to do with longevity. A simple damper-rod shock is cheap to make to a relatively high standard.
    The cheap 'cool looking' shocks from China sell in Asian markets for about 1/4 of what they sell for in the U.S., and they are total crap. We get gouged on them because they are still about the cheapest shock we can get.
    EMGO makes good stuff (they are an OEM supplier to many well-known brands of motorcycle). I wouldn't hesitate to fit a pair of their shocks if I were on a budget, and I'd expect to get as much use from them as the stock shocks.
    Having said that, you can get much better shocks for about $150 more per pair.
  9. Jetfixer
    Hagon makes a good shock but are $$$$ I just ordered a set of EMGO shocks for my seca bought other of their products for other bikes with good results.
  10. Bluegray57
    Bluegray57 Active Member
    US
  11. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    The good looking set of konis I bought turned up from Germany, stripped the springs off them to test them - one of them was kaput, only working half its length. Waiting for a reply from the seller. Itay be it just needs a seal and some oil, we'll see?
  12. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    Ok thanks guys you have given lots to think about
  13. Jetfixer
    Started installing the EMGO shocks got one mounted they look great ran out of time I have the factory saddle bag brackets a little harder . Can't wait till I can ride to see if handling is any different.
    Bluegray57 likes this.
  14. Bluegray57
    US
    looking forward to your report
  15. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    OK so I have a 1984 SECA 750 RL which is a 750 in a 900 frame. The shocks I'm looking at say the need a travel limiter. I'm confused a little as to why. Are the shocks all 325 from eye to eye or are mine different? My stock ones also have the reservoir on them will switching cause a problem. Here is some pics of my progress so far. Have a look and tell me what you think?
    https://ibb.co/iF5Gxe
    https://ibb.co/dSGH3K
  16. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
  17. Jetfixer
    Whoo finished installing the EMGO shocks it was drizzling so didn't take out far but already can tell feels much firmer and looks like one of my old shocks leaked st some point so this was a good investment . Only thing is shocks did not come with directions , but was easy enough to figure out. I paid 89$ so this was money well spent.
  18. RICKTOR
    RICKTOR New Member
    Winnipeg Canada
    Great... I think I am going to pull the trigger on these as well. But first can anyone tell me if all the bikes including my 1984 SECA 750 RL which is a 750 in a 900 frame have 325 mm eye to eye. The shocks I'm looking at say they need a travel limiter. I'm confused a little as to why. Are the shocks all 325 from eye to eye or are mine different?
  19. Praxeus
    Praxeus Member
    British Columbia
    Jetfixer, can you tell me what you did with the white plastic spacer thing in the coils? Is it there for some preload? I am not talking about adjustment with the spanning tool. I’ve got the Emgo shocks installed and I am curious if I’m supposed to take some pliers and rip em out lol.
  20. Jetfixer
    Never figured it out left it in place , might be a shipping thing not sure, but these shock feel much firmer than the original , I did not change setting , but I'm pretty happy with them .
    Praxeus likes this.
  21. Bushy
    Bushy Active Member
    RICKTOR that's a good looking well kept 750 RL you've got. Be good to it there aren't many of them. IKON shocks with adjustable damping on mine and happy with them.
  22. Toomanybikes
    Tsawwassen bc
    That plastic spacer is supposed to be there.
  23. Praxeus
    Praxeus Member
    British Columbia
    Thanks bud
  24. Praxeus
    Praxeus Member
    British Columbia
    I think I may notice mine more after I replace the swingarm bearings.
