Rear shocks Progressive 412s. '82 XJ750J Maxim
Discussion in 'XJ Technical Chat' started by Keeferheydude, Dec 19, 2025.
Tags:
  1. Keeferheydude
    Keeferheydude Member
    Edmonton. Alberta Canada
    Hello fellow Riders. I installed a set of 412s on the rear. At the 10 000 mile mark they are worn out. Is that a normal Lifespan for the 412s? I'm having a little trouble sourcing other brands. Any Suggestion would be great. Merry Christmas. Bike 520 Lbs wet, Me 180 Lbs. No passenger. Rough Alberta Prairie Roads..
  2. Dave in Ireland
    Ireland
    There's your trouble.
    Normally expect four or five times that on smooth tarmac, even on cheapies.
  3. Keeferheydude
    Ok. Thanks. Merry Christmas
  4. Fuller56
    Fuller56 Well-Known Member
    Are those shocks not rebuildable? An email to Progressive might be helpful to you.
  5. Timbox
    Progressive should work with you. Just guessing they are worn out? If Progressive has a way to test them, that would be great. Might only cost you shipping cost. Give them a call or email.
  6. Franz
    What tyres do you use Dave? What mileage do you get approximately?
  7. Dave in Ireland
    Ireland
    Usually Avon front and Maxxis rear, typically 8 to 10K rear, twice that for front.
  8. Franz
    That is good mileage Dave I will get them for my 900f cheers.
  9. Franz
    These ones ? Maxxis M6103 120/90-18 TL 65H Rear wheel
    Avon Roadrider MK II 100/90-18 TL 56H Rear wheel, Front wheel
  10. Dave in Ireland
    Ireland
    That's about it. The Maxxis ones I've been using are slightly different, but older stock. Probably exactly the same tyre, but they change up tread patterns and numbers every so often.
    The Avon Roadrider Mk II is the best front I've ever used, it suits every bike I've tried it on so far.
    Franz likes this.
