Rear wheel bearing - XJ900
Discussion in 'XJ Technical Chat' started by adrian1, Feb 16, 2018.
  1. adrian1
    adrian1 Active Member
  2. chacal
    HCP1838 OEM rear wheel BEARING, single-shield, high speed cylindrical roller bearing is an exact match of the original used on XJ750RL and all XJ900RK, RL, N/FN, and F models. Use in the following positions: in the inner position of the left side of the wheel hub.
    Marked: Japan, no mfg. name, DAC174021Z H1C on rim
    single grey metal shield
    16.96mm ID
    40.00mm OD
    20.95mm thick
  3. adrian1
    Much obliged Len! So the 20.95mm measurement refers to the wider inner sleeve, not the outer race? Cheers Adrian
  4. chacal
    Correct!
  5. adrian1
    Thanks again Len. Great service as always..
