Rear wheel to final drive spacer size
Discussion in 'XJ Technical Chat' started by cds1984, May 14, 2019.
  1. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    I have lost my spacer that sits inside the final drive (diff) that the rear wheel relies upon for my XJ900...
    I do have the spacers to suit a XJ750 but looking at parts lists and actually testing it out it seems to be much longer than the XJ900 version would be.
    Any chance someone has one lying about and can do a metric (or otherwise) measurement for me?
    Thanks!
    I've attached a pic of the bit I mean also.
  2. cds1984
    Actually... wrong part altogether... i think!
    According to what I'm looking at it is the same part number between the 750 and the 900... but it seems to stick out further when I insert it in the 900 diff in comparison to the 750 diff... mucho confusing.
    ack...
    This looks like the right bit,
  3. cds1984
    Colour me confused.
  4. XJ550H
    when in doubt refer to xj4ever catalog
    HCP12325 OEM final drive output/wheel clutch hub SPACER TUBE this almost 3” long tube spacer fits on the wheel side of the final drive housing, into the splined clutch hub on the left side of the wheel. If this spacer is missing, you will not be able to align the rear wheel properly side-to-side within the swingarm. For all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 12.95
  5. k-moe
    They are the same part. It's possible that the spacer you had was too short, homemade, or from a different application to begin with.
    Be sure that the bore is clean and free of hardened grease before fitting the spacer.
  6. cds1984
    Ahh XJ550H Good Call and K-Moe Good Advice.
  7. cds1984
    Aha!
    First time install for this diff and after a fiddle the reason was the sleeve coming from outside pushed into the diff.
    There was a washer jammed in on the outside, between the swingarm and diff that was wedged into the side of the diff.
    A couple of taps on the spacer from the inside and the washer popped out and the sleeve is realigned.
    Funny one.
