recent purchase '82 RJ SECA idling high rpm when warm
Discussion in 'XJ Technical Chat' started by pauldale999, Nov 5, 2011.
  1. pauldale999
    pauldale999 Active Member
    Nottingham, England, UK
  2. bigfitz52
    If you can get a nice deep blue at 3 turns out and an 1100 rpm idle with everything sync'ed up at that setting, leave it. "Read" the plugs after a couple hundred miles.
    Here's something that might help in any further troubleshooting: http://www.xj4ever.com/inside%20your%20carbs.pdf
  3. pauldale999
    Is it carb pilot air jet, OR cam chain loose??!!
    Just bought, and installed new, used, #4 carb body from Len.
    Re set the float level on #4 also....
    Can get equal sync, across all four dials on vac syncroniser, but still cant get below 1400, at temp, idle....unless I 'lean' the #4 pilot fuel system, OR, set vacuum dials on 3 & 4, slightly lower that 1 & 2. - namely 1 and 2 at '10', and 3 and 4, at '7' - Get nice 1050-1100 idle then.
    THERE ARE NO VACUUM LEAKS ANYWHERE!
    Turn #4 pilot down to 'very lean', and nice 1050 idle again...
    This is indicating that too much air is still being metered in to the mixture, on #4, at any given pilot fuel screw setting....?....cos when I turn the pilot screw 'out', to richen the mixture, it will only richen to a mid-light blue, (on the colortune), and the idle rises to 1400 (when perfect sync across all 4 dials), and will not richen any more, (and the rpm doesnt rise any more either) to the yellow (which is supposed to do when over-rich?), even advancing to all the way out.
    There should be no issue with pilot fuel supply now because of new, clean, used carb body, and pilot fuel jet.
    I looked at pilot air jet, and a micro sized bit of wear, - COULD THIS TINY ABBERATION CHANGE THE METERING OF AIR LARGE ENOUGH TO BE CAUSE OF INABLILITY TO PROPER TUNE #4 cylinder, and send idle +200-300rpm, unless I 'lean' it out???!!, or have less pressure on 3 and 4 carbs, than 1 and 2, at vac sync.
    Set vac sync to #s 1 and 2, at #10 on dials, and #s 3 and 4, at #7.5, on the dials, and nice 1050 idle again, with 'mid blue', color on #4 colourtune plug (all others adjusted nice also)
    Ive noticed its just the #4 valve/carb again, obviously....
    I CAN HEAR SOME CAMCHAIN RATTLE, WHEN ENGINE IS IDLING
    Says in Haynes, that mine (RJ), is manually adjusted cam-chain tensioner, and this should be tightened every 10,000 miles, if necessary, and 'noise is heard' - "the valve timing accuracy will be lost", and "the engine cannot run properly, if there is excessive play in the camshaft drive"......
    I have no idea when the camchain, was last adjusted/tightened, (this is +30,000 miles old) and it is slighty (?) loose, and that is why I am having problems adjusting to a proper colour/pressure, whatever on the #4 cylinder/carb....?
    Perhaps because of 'fluctuating' pressure..from #4 valve (it does 'surge', VERY slightly, every few seconds), and its at the loose (or tighter) end of the chain, when running, is 'upping' the pressure, firing at a slightly higher rate, and also raising the rpms, on that valve....?
    I think I should tighten the cam chain, as described in Haynes...and re-sync ...and if that does not cure it, change the pilot air jet....?
    :?: Anyone agree with my hypothesis.....?....PLEASE! SOMEONE??!!
    Regs. :?:
  4. pauldale999
  5. pauldale999
    *************LATEST***********************
    :) Just carried out procedure to tighten the camchain, and sounds quieter when idling - or is that just psychological.....? :?
    Idling nice anyway, at temperature, but not checked color on #4 yet.....
    :roll: Also, read in a thread, that use 25% less fuel if upgrade to 'bladed' fuse box, from the stock tubular glass one....any truth in that......??
  6. mtnbikecrazy55
    fuel consumption due to JUST the fusebox upgrade, highly doubtful.
