Wanted Red Seca 750 or 650 front fender
Discussion in 'For Sale, Trade/Swap, Wanted' started by Bob Salter, Feb 18, 2020.
  1. Bob Salter
    Bob Salter New Member
    toronto
    Looking for one with original paint in Nice shape.
  2. hogfiddles
    Which one—- they are different
  3. Bob Salter
    toronto
    Preferably a Seca 650 fender, but as i understand it, the 750 is very similar and fits, as well as being the same Red as a Canadian 650.
  4. Bob Salter
    toronto
    Also looking for passenger's seat strap for a 650 Seca
  5. chacal
    Fenders:
    XJ550 Seca and XJ650 Seca use the exact same fender, besides the color differences. The 1981 XJ550 Seca fenders were chrome-plated, rather than painted. The 1982 XJ750 Seca fender (Color Code T5 Red) is about as close to the Canadian XJ650RJC color (Code 4H Cardinal Red) as you'll likely find...…...the 750 Seca "red" colors are not anywhere near as close.
    The XJ750 Seca fender is the same as the XJ550 Seca and the XJ650 Seca fenders, but it has an additional slotted opening underneath the main triangular opening. Other than that, they're the same.
    We do have the correct Code 4H Cardinal Red paint available (but cannot ship it into Canada), but since you're near the border, it could be shipped to a location within the USA and you would have to drive over and pick it up...…..
    The 1981 XV920RH Virago also uses the same fender as the XJ550 Seca/ XJ650RJ Seca models, it was available in a Code 63 Brilliant Red, but again, close in color but not the same.
    Seat straps:
    HCP19143 Aftermarket SEAT STRAP MATERIAL, 24" section of reproduction seat strap/band material. Does not include any strap hardware. Although this material is slightly wider and slightly thinner than the original material, it is very close in design and appearance tand the differences can only be noticed If an original strap is placed directly next to it. Black. Fits all XJ550 Seca, XJ550 Euro, XJ650RJ Seca, and XJ650 Euro model seats.
    $ 19.95
    HCP16600 OEM seat strap BUCKLE, bright-plated stamped buckle fits at each end of the strap and is used to secure the strap to the seat pan. Use 1 per side, 2 per seat. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Each:
    $ discontinued
    HCP16559 Aftermarket seat strap BUCKLE, polished, stamped, stainless steel buckle fits at each end of the strap and is used to secure the strap to the seat pan. Nice reproduction of the original features the “flat, squared” bottom which is correct for Yamaha models. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Use 1 per side, 2 per seat. Each:
    $ 15.95
    HCP27137 Aftermarket seat strap BUCKLE, stamped, chrome-plated steel buckle is a correct reproduction of the original, and is fitted at each end of the strap and is used to secure the strap to the seat pan. Correct reproduction of the original features the “flat, squared” bottom which is used only on Yamaha models. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Use 1 per side, 2 per seat. Each:
    $ 19.95
    HCP26790 OEM seat strap FLAT WASHER, fitted on each side of the clinch rivet which goes thru the strap and clasps the end of the strap together (securing the strap to the buckle). Bright-plated. Use 2 per side, 4 per seat. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Each:
    $ discontinued
    HCP26953 Aftermarket seat strap FLAT WASHER, fitted on each side of the clinch rivet which goes thru the strap and clasps the end of the strap together (securing the strap to the buckle). Bright-plated alloy steel. Use 2 per side, 4 per seat. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Each:
    $ 5.95
    HCP27138 Aftermarket seat strap FLAT WASHER, fitted on each side of the clinch rivet which goes thru the strap and clasps the end of the strap together (securing the strap to the buckle). Bright-plated stainless steel.. Use 2 per side, 4 per seat. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Each:
    $ 6.95
    HCP16601 OEM seat strap CLINCH RIVET, used to cinch the strap ends together (thus securing the strap to the buckle). Bright-plated. Use 1 per side, 2 per seat. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Each:
    $ discontinued
    HCP16598 Aftermarket seat strap CLINCH RIVET, used to cinch the strap ends together (thus securing the strap to the buckle). Bright-plated, correct large flat-head design and appearance as original. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seat straps. NOTE: in order to properly cinch this rivet (to splay the end of it, much like on a drive chain master-link), we recommend the use of the HCP27621 tool, which is available for rental. Otherwise you will need to locate an upholstery shop that has such a tool in order to properly (safely) “mushroom” the end of the rivet tip. Use 1 per side, 2 per seat. Each:
    $ 10.95
    HCP4327 OEM seat strap SCREW, used to retain the buckle (and thus the strap) to the seat pan. This special bright-plated, phillips-drive, shouldered screw has the cotter pin hole at the end of the threads, and is fitted through the hole in the buckle. Use 1 per side, 2 per seat. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Each:
    $ discontinued
    HCP16483 Aftermarket seat strap SCREW, used to retain the buckle (and thus the strap) to the seat pan. This special bright-plated, phillips-drive, shouldered screw has the cotter pin hole at the end of the threads, and is fitted through the hole in the buckle. Use 1 per side, 2 per seat. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Each:
    $ 14.95
    HCP4328 OEM seat strap bolt retaining HAIRPIN CLIP. Use 2 per seat on all XJ550 Seca and XJ550 Euro models. b]NOTE[/b]: this is a hairpin style clip that is much easier to install and remove, and is our preferred style to use on XJ650RJ Seca and XJ650 Euro seats instead of the straight “true) cotter pins originally used. Each:
    $ 3.95:
    HCP11500 Aftermarket seat strap bolt retaining HAIRPIN CLIP. Use 2 per seat on all XJ550 Seca and XJ550 Euro models. Each:
    $ 1.95
    HCP27139 Aftermarket complete seat strap BUCKLE KIT…..contains all the parts needed to fully rebuild or replace a seat strap buckle assembly: a pair of chrome-plated buckles, a pair of the special buckle mounting (to the seat pan) screws and their retaining clips, 2 clinch rivets and the flat washers used with the clinch rivets, and a pair of the u-shaped inner reinforcing brackets. Your seat strap will be the belle of the ball with this beautiful replacement hardware. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. NOTE: strap material is not included. Clinch rivet tool HCP27621 is not included.
    $ 54.95
    HCP27140 Aftermarket complete seat strap BUCKLE KIT with STRAP…..contains all the parts needed to fully replace or rebuild a seat strap buckle assembly a pair of chrome-plated buckles, a pair of the special buckle mounting (to the seat pan) screws and their retaining clips, 2 clinch rivets and the flat washers used with the clinch rivets, a pair of the u-shaped inner reinforcing brackets, and a length of reproduction black seat strap material. Used on all XJ550 Seca, XJ550 Euro, XJ650 Euro, and XJ650RJ Seca seats. Clinch rivet tool HCP27621 is not included.
    $ 69.95
    HCP27621 Aftermarket seat strap rivet CLINCHER TOOL, used to splay the end of the clinch rivet and secure it tightly. Although it’s not absolutely necessary to use this tool to splay the rivet tip, it sure makes the job easier (and prevents you from ruining a bunch of rivets as you practice your technique!). If you’re going to have your strap “rebuilt” by a trim (upholstery) shop, then they probably already have a version of this tool (but you should ask them first). This tool is available for rental, since you probably only need to use it once in your life. For use with the HCP16598 clinch rivet above.
    $ 39.95 purchase price
    $ 1.95 per day rental. *Please see the “rental” section within the THE TOOLBOX section of our catalog for rental rates and details at:
    $ 19.95
    $ discontinued
    $ 15.95
    $ 19.95
    $ discontinued
    $ 5.95
    $ 6.95
    $ discontinued
    $ 10.95
    $ discontinued
    $ 14.95
    $ 3.95:
    $ 1.95
    $ 54.95
    $ 69.95
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
  6. Bob Salter
    toronto
    Wow, you have seat straps covered. Thanks for the information on the paint and straps. I did not realize that the color was different for the Cdn Seca 650 and 750. I am ideally after original paint, unless I change my mind and repaint the whole bike. That would be pretty far down the road.
