relocating choke
Discussion in 'XJ Modifications' started by cg82, Jun 28, 2013.
  1. hogfiddles
    This is the same type of enricher that is on the Suzi VL1500LC
  2. Diversion
    Diversion New Member
    SW Australia
    I moved mine, but not to under the tank. I've put clubman-style cafe-racer handle-bars to my XJ650 (Seca) 4KO, and the choke kept hitting the tank on full left lock when I was wheeling the bike out of the pits.
    I moved the choke to between the instrument cluster and the ignition barrel, using the left-hand instrument-cluster mounting-bolt (I had to put a slightly longer bolt in).
    I used the cable from an XJ900S, and made a very simple bracket from Al bar, with two holes of appropriate diameter.
    Franz and XJ550H like this.
  3. robawf
    robawf Member
    I ditched the cable completely and put a spring loaded thumb knob on the existing linkage arm. I welded the cable connection up, ground it flush and drilled it out to accept the knob. The choke holds where ever I want it and it's conveniently right next to the fuel petcock.
  4. Steve Runquist
    Steve Runquist New Member
    Minnesota
    Can you send photos robawf?
  5. robawf
    robawf Member
    It just so happens that I have my carbs off the bike right now disassembled. I'm putting them back together tomorrow. That would be the opportune time for pictures of the choke set up. I'll post pictures sometime this coming weekend.
  6. robawf
    robawf Member
    It's nothing fancy, real simple. I used a 1/4-20 aluminum thumb screw, a spring and a cut down thread protector. All found in my bottomless junk drawer. It stays wherever it's set at and it was free..... 2017-02-17 19.14.13.jpg
  7. robawf
    robawf Member
    I remembered that I did end up welding the control rod to the lever. As it sits from the factory; its a press fit configuration which becomes sloppy. Ground it clean, media blasted it then shot it with some clear.....
  8. Rodney Watson
    Rodney Watson New Member
    Anchorage, AK
    Do you have a picture of this setup? Also, which bike lever? Gear or brake?
