Removed the Engine, now what?
Discussion in 'XJ Technical Chat' started by swedishlinus, Jan 9, 2021.
  1. swedishlinus
    swedishlinus New Member
    Sweden
    Im rebuilding a XJ600(Fj600) 51J from 1985 and I removed the engine today from the frame. The plan is to repaint it and check the valve clearance. what else should i check/service when the engine is easy to access?
    Can i check the wellbeing of the alternator and starter?
    do you have a motor stand/cradle?
    you can clean the alternator rings on the rotor. consider replacing the brushes.
    inspect the clutch .
    if your going to open up the starter may as well rebuild it unless it is in great shape .
    StarGeneral likes this.
  3. swedishlinus
    Sweden
    No stand or cradle! Thanks, i will have a look at those parts. Just going to clean 35 years of oil/sand crud of the engine first.
  4. StarGeneral
    StarGeneral Active Member
    Oregon, USA
    Im barely further along in my project than you and this is my first motorcycle (though I've worked on cars a fair bit in the past). All I can say is please please don't do the minimum needed to get the bike rolling. Other members here have paid the price in money and blood lol. I would work on anything you can afford to while you have the bike apart.
  5. swedishlinus
    Sweden
    I did this mistake last winter. Nos i want to make it proper. But splittibg the engine seems a bit to much. Hence the question on what should be done!
  6. Franz
    Things to check have already been mentioned but you can also rebuild your carburettors, check your cam chain tensioner to ascertain how far the plunger is extended, change your valve cover gasket.
  7. XJ550H
    check the donuts on the cover they may be hard and need replacing I would change them first before gasket.
  8. swedishlinus
    Sweden
    The cover gasket is being changed, actually bought it over a yesr ago, but misplaced it in my tiny shop (turned out it was in an envelope in a stack of old bills). It has beeen leaking from that gaskeh for quite some time.
  9. XJ550H
    I am finding that it is the hardened donuts that causes the leaks more times than the gasket.
  10. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Not always though. I replaced the donuts but wanted to wait till the next riding season to replace the cover gasket which I also have. Still leaks!
    XJ550H likes this.
  11. StarGeneral
    Oregon, USA
    If you're not 100% about the integrity if your oil seals you could split the cases. That's what I'm planning to do. I plan on cleaning the heads and re-grinding the valves on the way.
  12. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    There are bikes on ebay and craiglist and arsebook everyday that have been stripped and left in bits.
    All of the things you've been encouraged to check could have been done with the engine in the frame. Do the valves, cover, any leaking gaskets, tidy it up and put it back ink asap...
    Spring will be here soon. If you miss the riding season the bike will become a project for sale.
  13. a100man
    a100man Well-Known Member
    Bedford, UK
    If you've heard it running and it sounds OK and isn't smoking too bad then check valves, check compression and change the oil - anything else is Brooks Brothers* territory..
    * an Apocryphal tale of two brothers who once lived in a North Bedfordshire village in England. Spent every weekend pulling apart their Rover car to see why it was running so well.
    Franz likes this.
  14. swedishlinus
    Sweden
    Haha, how else would you know? ;)
    i have ridden it and it everything is good. A bit hard to start, but i guess thats due to the carbs and that i need to do them one more time.
    another question regarding this engine. I wanna paint it before putting it back. Are the cylinders, head and top cover the only parts that need heat resistant paint? Since almost all heat paint needs to be heat cures, i guess that some of the parts wont get properly cured.
  15. swedishlinus
    Sweden
    That is what happened this summer and this time around i will take my time with it instead. I have a kind summer guest in our village that wants his bike ridden, so im glad to help him! But thanks for your concern.
  16. hogfiddles
    I would change them AND the gasket after getting valve clearances in spec
    Franz likes this.
  17. a100man
    Bedford, UK
    Ive used some stuff called Granville Cylinder & Head satin black but its brush on. It does cover well and is impervious to oils etc.. but the colour isn't quite pure black when viewed in sunlight. My other 'favourite was Plastikote stove paint which used to be satin but is now more of a matt finish in the last can I bought. :-( I get the impression that VHT paint in general resist fluids better (petrol etc..) You can of course paint the clutch covers etc with normal rattle can but durability will be questionable both through scratch and spills. BTW anything the Americans recommend probably isn't easily available here. You could also try the selection that Frosts Restoration in the UK sell (expensive though).
    Edit: -this not too expensive and cures at 90 C (not tried by me though).. https://www.frost.co.uk/vht-satin-black-engine-enamel-high-temperature-paint-312g/
  18. swedishlinus
    Sweden
    A little update. I missed that it was some sand particles on the head which fell down when removing it. So im making the best of the situation and splitting the engine in the spirit of Bedfordshire brothers. Found out that a shop closeby is doing vapour and wet blasting so the case and cylinders will go there for pre pint prep.
  19. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    I recently had the cylinder / head unit vapor blasted & painted and had problems with paint adhesion. The blasting left the surface feeling slightly waxy which may have simply been a smoothing of the surface. Although the surface was thoroughly cleaned and scrubbed and a heat-resistant etch primer was applied, the paint didn't stick perfectly. So I stripped the new paint and lightly sandblasted the surface. It's been repainted with no adhesion issues.
  20. swedishlinus
    Sweden
    I will keep that in mind. The shop does powder coating, so i think im going for that.
  21. swedishlinus
    Sweden
    Got the crank case split. But i cant remove the starter clutch gear. The one that is attached with a 30mm nut. Any ideas for how to hold it still while removing it?
  22. Franz
    Do you mean the clutch nut in the centre of the basket? I ask because I have not seen a starter clutch with a 30mm nut. You need a clutch basket holding tool like this or make one out of scrap metal, easy to do if you have the time. The nut has a locking tab you need to flatten too.
  23. swedishlinus
    Sweden
    Sorry, its not 30mm. I got the clutch basket of. Its the sprocket on the other side of the engine. I think Clymer calls it the main drive sprocket or something.
  24. Franz
    Is it a chain drive bike or shaft drive?
  25. hogfiddles
    Ok, for those of us who didn’t read all the way from the beginning, now we know. I found it
    Franz likes this.
  26. Franz
    Final drive or main drive sprocket. Ok if you have a vice with jaws wide enough you can put two pieces of timber on the sprocket and tighten the vice so the sprocket teeth bite into the timber. Then try and slacken the nut.
