Removing brake line splitter
Discussion in 'XJ Technical Chat' started by noah scott, May 21, 2022.
  1. noah scott
    noah scott Member
    McMinnville, Oregon
    so, I'd like to switch from having 3 brake lines to 2... i need to order new brake lines anyways, so i'd like to try this.
    i think all i would need is
    2- need to re-measure, but i think 42" brake lines (Goodridge for example)
    - https://www.summitracing.com/parts/gdr-10344
    4 - 10mm banjo fittings (correct angle of course)
    - https://www.summitracing.com/parts/gdr-593-03bk
    1 - dual line 10x1.25mm banjo bolt
    - https://www.summitracing.com/parts/gdr-993-03-32c
    a few extra crush washers.
    Does that sound about right, for people that have done this previously?
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    yeh, that sounds about right, i assume you mean to run two brake lines direct from the master cylinder to each calliper?
    some bikes run one line from the master cylinder, to one calliper then a second one from that , up and over the front fender to the other side.
    daft aint it , its a lot cheaper doing it with just 2 lines
  3. noah scott
    noah scott Member
    McMinnville, Oregon
    You got it.
    I was thinking over the fender from one caliper to another but I feel like the pressure wouldn't be even... But it probably would, but im not a mathamascientist...
    But yeah, just 2 direct lines from the master cylinder, one for each caliper
  4. Dave in Ireland
    Ireland
    It would. Fundamental hydraulics.
    Franz and jayrodoh like this.
