Removing emulsion tubes from Hitachi carburetors
Discussion in 'XJ Technical Chat' started by Gary Potter, Jan 6, 2022.
  1. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I am rebuilding my Hitachi carburetors and in "The Church of Clean", the emulsion tubes need to be cleaned. How do you remove these tubes from the carb body? Thanks ahead of time for your help here.
  2. Dan Gardner
    Minneapolis, MN
    They are held in place by the main fuel jet. If you've got the main removed, you should be able to (carefully) get it out.
  3. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    What would you recommend I use to get it out?
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    i use a small wooden drift to tap it out, i use a square rocket stick shaved down circular.
    Jetfixer likes this.
  5. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    So I knock it out from the open top of the carb, correct?
  6. Dan Gardner
    Minneapolis, MN
    <retracted>
  7. chacal
    No, it comes out the top! You have to tap on it from the bottom (where the main jet was screwed into it) and push it thru into/through the carb throat.
    hogfiddles, Franz and Huntchuks like this.
  8. Dan Gardner
    Minneapolis, MN
    Whoops, sorry. My bad
  9. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    Thanks! That makes sense. I appreciate your help.
