Replacement Gas Cap?
Discussion in 'XJ Modifications' started by Attom, May 23, 2019.
  1. Attom
    Attom New Member
    Middle Tennessee
    Not sure if this is the best forum to post this in, but I guess we'll see.
    The gas cap on my bike is majorly corroded. I have cleaned it up several times but it just crusts right back over. With in a day the key doesn't work to open it. Last time it got stuck shut I was on the road and had turn the lock with a screwdriver. Now it is stuck in the unlatched position, which would be fine except it spill gas, might let water in and vibrate a lot, so not really so ok.
    I need to replace it. I would rather find a non-locking cap that fits the tank... is there anything out there that would work? Would like it the screw down where the old cap is now with out modifying the tank. Something like an aviation or Monza cap.
    Toomanybikes likes this.
  3. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    XJ550H likes this.
  4. Attom
    Attom New Member
    Middle Tennessee
    Thank you, I may go with one like that (that specific one says it does not fit an 82 Maxim), but was really hoping to go keyless.
  5. raskal
    my '82 Maxim has a keyless gas cap.
    any screwdriver will open it
  6. XJ550H
  7. XJ75082
    XJ75082 Member
    Central Texas
    I have been looking at the cap from the radian(built from the 550maxim). Same tank different cap style and still available from Yamaha. Only major issue is. It mounts with 3 bolts. So 2 holes would have to be drilled & tapped.
  8. XJ75082
    XJ75082 Member
    Central Texas
  9. XJ550H
    it is a bit more complicated than 2 holes
    you would be better off putting a raidian tank on your bike . you may have to mod the tank as I do not know if it would direct fit. the shape of maxim is different than a radian tank
    XJ75082 likes this.
  10. XJ75082
    XJ75082 Member
    Central Texas
    I see the difference now. Thanks for pointing out that. Yamaha sure didn't make easy on us old bike enthusiast
