RobbieRobot Cafe Racer Project in pictures
Discussion in 'XJ Modifications' started by RobbieRobot, Jul 16, 2013.
  1. RobbieRobot
    RobbieRobot Member
    North Yorkshire, England
    A sneak peek but I'm not sure I want to keep the tank.
  2. RobbieRobot
    RobbieRobot Member
    Time to figure out the wiring.
  3. RobbieRobot
    RobbieRobot Member
    New switches being sorted.
  4. RobbieRobot
    RobbieRobot Member
    New heat shrink tubing on the right switch assy.
  5. RobbieRobot
    RobbieRobot Member
    Then the left switch assy.
  6. RobbieRobot
    RobbieRobot Member
  7. RobbieRobot
    RobbieRobot Member
    Switch gear all working correctly.
  8. RobbieRobot
    RobbieRobot Member
    Carbs back on and she runs. Still need to do a full strip and glass blasting of the carbs though, with new tube seals etc.
  9. RobbieRobot
    RobbieRobot Member
    New fuse box.
  10. RobbieRobot
    RobbieRobot Member
    Left brake caliper re-assembled with new seals, Brembo pads and Goodridge SS braided hoses.
  11. RobbieRobot
    RobbieRobot Member
    Re-con Darmah tank arrives so I try it for size.
  12. RobbieRobot
    RobbieRobot Member
    Note the mock-up battery tray. It's a baking tray I nicked from the long-suffering missus.
  13. RobbieRobot
    RobbieRobot Member
  14. RobbieRobot
    RobbieRobot Member
    Don't worry. The tank will eventually be re-sprayed.
  15. RobbieRobot
    RobbieRobot Member
    Mods to make it fit.
  16. RobbieRobot
    RobbieRobot Member
    Right hand caliper fitted and brakes bled (with some difficulty).
  17. RobbieRobot
    RobbieRobot Member
    Stainless steel mudguard gets the chop.
  18. RobbieRobot
    RobbieRobot Member
    Full movement check. Plenty of clearance.
  19. george2524
    george2524 Member
    Maryland, USA
    That tank looks sweeeeet!!!
  20. k-moe
    The tank does look nice on the XJ. Too bad that it didn't come with the rest of the Dharma though; those were sweet bikes in their own right.
  21. david502
    david502 New Member
    Auckland, NZ
    It is only right that this thread gets my first post. This build is awesome.
  22. RobbieRobot
    RobbieRobot Member
    Thanks for all the feedback. I've been too busy working on the bike since March but last night I thought I'd make the effort to share it, especially as I've used this site for loads of technical assistance. There is still some way to go so I'll continue searching for the wise words of the experts notably RickCoMatic and Bigfitz52. Thanks guys. Meanwhile we're having a heatwave in the good old North East of England so I may be easing off a little on the hours.
  23. broberg
    broberg Member
    Sweden, Östergötland
    Really Nice build, and that tank is awesome!
    But you really need to make a new bracket for the dials :) (unless your going for fairing as well?)
  24. TIMEtoRIDE
    Are you going to "correct the lines" of the seat pan now that the tank is fitted? (it doesn't look like you can simply lower it)
    That IS a nice looking tank !
  25. steber
    steber Active Member
    Scranton, Pennsylvania
    Looking good so far. Love the tank. I see you went with pegs moved back. flipped shifter seems to do the trick. What are you doing on the brake side to account for the move?
  26. RobbieRobot
    RobbieRobot Member
    Cheers broberg. I'm not planning on fitting a fairing. I have an instrument bracket from a CB750 which I'll be trying out towards the end of the build but I quite like the high clocks. Nothing is set in stone yet, cosmetically.
  27. RobbieRobot
    RobbieRobot Member
    Cheers
    That photo was taken 5 minutes after I took the tank out of the box. It's not fitted yet, just propped on foam blocks. I will be looking at finalizing the cosmetics once the battery and electrics are repositioned and secured.
  28. RobbieRobot
    RobbieRobot Member
    Cheers Steber. Yes, so far so good.
    I may be looking at fitting rear-sets at some point in the future but as it stands those are stock pegs re-fitted in the original position. Remember it's a UK SPEC bike.
  29. RobbieRobot
    RobbieRobot Member
    Not happy with the mounting bracket I previously welded on the tank so removed it.
    [​IMG][/URL]
  30. RobbieRobot
    RobbieRobot Member
    Welded some new attachment brackets onto the tank.
    [​IMG][/URL]
  31. RobbieRobot
    RobbieRobot Member
    Attachment brackets.
    [​IMG][/URL]
  32. RobbieRobot
    RobbieRobot Member
    Now to prepare the tank.
    [​IMG][/URL]
  33. RobbieRobot
    RobbieRobot Member
    Tank rubbed down.
  34. RobbieRobot
    RobbieRobot Member
  35. rozko
    rozko New Member
    Poland
    Hi, what kind of rear fender is that? Im looking for spmething like that but without any succes...
  36. RobbieRobot
    RobbieRobot Member
  37. rozko
    rozko New Member
    Poland
    Thanks RobbieRobot!
  38. kinen1
    kinen1 Member
    Perth, Western Australia
    I really like the look of the tank! can't wait till u have finish with the bike! :)
    kinen
  39. RobbieRobot
    RobbieRobot Member
    Thanks kinen1. I hope to be getting back to putting the hours in soon having spent most of August touring and walking in the Lake District, The Yorkshire Dales and the Scottish Borders with the wife and our dog Mollie while the wife was on school holidays.
  40. RobbieRobot
    RobbieRobot Member
    Front mudguard stays being fabricated.
  41. RobbieRobot
    RobbieRobot Member
    Front mudguard fitted.
  42. RobbieRobot
    RobbieRobot Member
    Mudguards fitted
  43. RobbieRobot
    RobbieRobot Member
    Carbs dismantled
  44. RobbieRobot
    RobbieRobot Member
    Carbs soda blasted.
  45. RobbieRobot
    RobbieRobot Member
    Electrics tidied up a bit.
  46. RobbieRobot
    RobbieRobot Member
    Mounting plate for electrics.
  47. RobbieRobot
    RobbieRobot Member
    Battery mounted.
  48. RobbieRobot
    RobbieRobot Member
    Carbs ready for reassembly.
  49. RobbieRobot
    RobbieRobot Member
    Extreme cleanliness is a must.
  50. RobbieRobot
    RobbieRobot Member
    Throttle shafts re-fitted with new seals.
