RobbieRobot Cafe Racer Project in pictures
Discussion in 'XJ Modifications' started by RobbieRobot, Jul 16, 2013.
  1. bobcat5540
    bobcat5540 Member
    Mount Sidney,Virginia
    Research Por-15. It's an organic paint that cures hard when the temperature gets to 300*. You can spray it or brush it on.
    But wear a good mask this stuff will give you a good headache .
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    robbie,
    what are those plugs you used to plug the intakes prior to spraying?
    cheers
    stu
  3. FtUp
    FtUp Well-Known Member
    pacific northwest
    looks like the rubber feet off crutches or for a cane.
    CN
  4. lacucaracha
    lacucaracha Member
    Napa, CA
    Man, every time I get discouraged, all i do is look at your bike and get the itch to go back into the garage. Your bike is awesome.
  5. RobbieRobot
    RobbieRobot Member
    North Yorkshire, England
    They are, as CN has commented, the type of rubber feet as used on chair legs, walking sticks, etc. Purchased at B&Q several years ago. I usually find a use for things eventually.
  6. RobbieRobot
    RobbieRobot Member
    That's so kind of you and also very encouraging to me to stick at it despite the freezing temperatures out in the garage. Thankyou.
  7. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    This is an awesome project thread, now all I need is to send my child to college so I can have time… wait she is only 1 year old… oh well, one day
  8. RobbieRobot
    RobbieRobot Member
    Ha ha ecologito, you are in the same position as I was 28years ago. Enjoy it while it lasts. You'll soon wonder where time has gone, as I do now.
  9. RobbieRobot
    RobbieRobot Member
    Automatic cam chain tensioner fitted.
  10. RobbieRobot
    RobbieRobot Member
    Engine 'B' ready to be fitted into the frame.
  11. RobbieRobot
    RobbieRobot Member
    Engine 'B' lifted into the frame.
  12. RobbieRobot
    RobbieRobot Member
    Engine 'B' in the frame.
  13. bendoza
    bendoza Member
    portland, or
    hell yes!
  14. RobbieRobot
    RobbieRobot Member
    Engine 'B' all ready to test run.
  15. RobbieRobot
    RobbieRobot Member
  16. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Awesome. Congrats, Rob!
  17. RobbieRobot
    RobbieRobot Member
    :D
  18. RobbieRobot
    RobbieRobot Member
    :D
  19. RobbieRobot
    RobbieRobot Member
    First test ride up and down the street a couple of times. All seems well so far. I'm looking forward to getting the seat back from the upholsterer now. When I last spoke to him I told him I'd had a set-back so there was no rush. I'm going to have to get back to him now and let him know things are back on track.
  20. Heyitsme
    Heyitsme Member
    Seattle, wa
    Well done man, You built a very nice bike. What paint did you use for the engine?
  21. RobbieRobot
    RobbieRobot Member
    Thanks Heyitsme.
    The paint I used is the same paint I used on engine 'A' after extensive research and testing. For the brief life of engine 'A' it held it's colour well and withstood oil and petrol contact as it did during the testing process. I first heard about it on another website where a guy had tested several products and recommended this because it performed so well and doesn't need oven curing. The paint is Simonez Wheel Silver and is a pleasure to work with. The first engine's lower half was sprayed but the head and barrels were bare media blasted aluminium and the colour match was very similar.
  22. RobbieRobot
    RobbieRobot Member
    Today I rode the 30 mile round trip to the auto trimmers shop, the same trip that ended in disaster for the original engine. I'm pleased to report that the seat tailoring exercise went well and after some trial fitting we ended up with a very comfortable and well adjusted riding position for the foam. The guy says that's the hardest part over, the easy bit for him is making the cover and stitching it all up. He hopes to have it finished in about a week although he is extremely busy and has about 20 other motorcycle seats on the go. Can't wait to get it back. The bike didn't miss a beat all the way there and back and although I was mostly cruising at 60 I did get up to 80 at one point. A quick look at the plugs when I got home indicated that things can't be too far out as they were a nice light brown. I expect to be experimenting with jetting for performance in the upper band at a later date but so far so good upto now. My plan for this weekend is to strip all of the steel fasteners, brackets and bits and pieces and take them along to a highly recommended company for zinc electro plating. All in all a good day. Now to get this last 12 hour nightshift done and dusted.
  23. Andyam6
    Andyam6 Member
    UK, Beds
    Great news
  24. RobbieRobot
    RobbieRobot Member
    Outside the Auto-Trimmers shop with seat foam prior to trimming.
  25. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    love this bike
  26. RobbieRobot
    RobbieRobot Member
    This weekend I decided to re-visit the mudguard (fender) mounting. So, to begin with, I made a cardboard template and went from there.
  27. RobbieRobot
    RobbieRobot Member
    Then I cut out two alluminium plates from a 3mm sheet.
  28. RobbieRobot
    RobbieRobot Member
    Then I formed and drilled them.
  29. RobbieRobot
    RobbieRobot Member
    Then after polishing I fitted them.
  30. RobbieRobot
    RobbieRobot Member
    I think they turned out quite well and are a big improvement.
  31. RobbieRobot
    RobbieRobot Member
    I shortened the mudguard a bit. Partly because I didn't want it flapping about and partly to remove the rear section that had previously been drilled.
  32. RobbieRobot
    RobbieRobot Member
    The end result is very rigid and I even cut-up an old rubber inner-tube and sandwiched it between the alloy bracket and the stainless steel mudguard to minimize corrosion.
  33. Andyam6
    Andyam6 Member
    UK, Beds
    Much nicer but wouldn't they be even better inside the mudguard?
  34. RobbieRobot
    RobbieRobot Member
    Thanks Andy, This is where I got the inspiration for the design and I really like it. As they say, you can't please all of the people all of the time!
  35. Andyam6
    Andyam6 Member
    UK, Beds
    See what you mean, it was just a suggestion
    It's your bike, it should be done your way
    I still love it by the way
  36. RobbieRobot
    RobbieRobot Member
    A couple of photos of my first Café Racer. It's a Triton and I was 18yrs old at the time err... about 37yrs ago. I'd just finished re-spraying it.
  37. BaldWonder
    Oberlin, OH
    No. It belongs to the people of the interwebs now. You must sate us all.
    Looks awesome, Robbie. Can't wait to see the seat, too. And nice flashback picture.
  38. RobbieRobot
    RobbieRobot Member
    Thanks BW, one tries one's best. Ha ha
  39. RobbieRobot
    RobbieRobot Member
    Just collected the seat today after several weeks waiting. The quality and workmanship are superb but I think I'll go back and see if he can improve the transitional appearance where it abuts the tank. On the positive side the seating position, height and comfort are perfect.
  40. RobbieRobot
    RobbieRobot Member
  41. RobbieRobot
    RobbieRobot Member
  42. RobbieRobot
    RobbieRobot Member
  43. RobbieRobot
    RobbieRobot Member
  44. FtUp
    pacific northwest
    ha! I was going to say the only issue I have is that "transition" otherwise, you nailed it! nice work!
    CN
  45. BaldWonder
    Oberlin, OH
    That is unfortunate... if it had just angled forward instead of backward. And it's probably going to mean starting over completely to alter it. Did the guy working on it not have the bike present to see how it fit? Was he just going off the tail section?
    That aside, it looks otherwise perfect. Great style, and the rivet finish really helps tie everything together. Jealous. I think the cafe bug has officially bitten me. My bobber needs a brother. :)
  46. RobbieRobot
    RobbieRobot Member
    Yeah, he should have angled it forward instead of back. I took the bike over twice for him to get measurements but it was his colleague who cut the foam. I rode it back over there today and he is prepared to re-do it but he is just too busy and has no room to store the bike. I've come away with a piece of the material to try and attempt a temporary fix until he has more time. Not to worry. I'll see what I can come up with. In fairness It was originally going to tuck under the tank but after it was done it looked better abutting the tank.
  47. RobbieRobot
    RobbieRobot Member
    A video of me setting off to the Auto Trimmers to talk about tweaking the seat.
  48. RobbieRobot
    RobbieRobot Member
    A photo stop along the North Yorkshire coast.
  49. BaldWonder
    Oberlin, OH
    What if you add a pad on the knee indent of the tank, and have that pad extend over the gap?
  50. RobbieRobot
    RobbieRobot Member
