Rust Inside Frame
Discussion in 'XJ Technical Chat' started by LPKirby, Oct 22, 2020.
  1. LPKirby
    LPKirby New Member
    Toronto, Canada
    I chopped the back end off my frame a few years ago and have only gotten back to it now. I'm planning on welding it back up but noticed some surface rust inside the tubes where it was cut. It appears it hasn't compromised the structural integrity yet, however I'm unsure how far up the rust has travelled. If I weld the back end on will the rust continue to eat away at the frame? How should I treat this?
    Side question: What material should I use for the frame modification?
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Don't know about material for future mods, but surface rust in the upper members shouldn't be an issue. The real problem is the lower front rails, water gets in there and rots them. You don't know about it until holes appear.
    LPKirby likes this.
  3. XJ550H
    there are drain holes in the frame if your concerned about the rust pour some evaporust inside the frame it will drain out and will stop the rust.
    mod tubing mandrel over die or something like that is what mod stands for
    tcbros.com sells tubes and things
    or look on ebay for oldmanmotors he sells hoops got one for a bike xs 650 was what it is for but it is same size
    LPKirby likes this.
  4. LPKirby
    LPKirby New Member
    Toronto, Canada
    I will definitely be ordering from oldmanmotors. Awesome, thanks for the advice.
